lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
Yea, it's got steel tanks... or at least the back one is steel. Previous owner said he replaced one of the tanks but couldn't remember when or which one, I'm assuming it was the rear tank (the one that sprung a leak) cuz it doesn't have any undercoating on it. Guy prolly cheaped out an got a tank made in china....If it only took one good bump to make it leak, it's probably better you discovered it now rather than driving down the road sometime...
Do those have metal tanks? I thought ford had learned their lesson about steel gas tanks by then? No?
So I started looking around for a new tank, LMC (and a couple other places) only have metal tanks and all but one wants $120-160 for a metal tank. The other place with a steel tank is local (over in the middle of the state) and they want $70 for one, plus it's in stock and would be here right away. The few poly tanks I was able to find start at around $130 and go up to near $200. I kinda hate to drop the extra coin on a poly tank cuz I have no idea how long I'll have this truck, but at the same time I don't want the tank to rust out in a couple years. I thought about dropping the tank that's in it now an see about fixing it, but if the seam split that easily, it prolly isn't worth trying to fix.
