ranger tow rig
link040188
⭐Supporting Member
flowood, ms
will a new 4.0 ranger be enough to tow my 4.0 4x4 to the trail?:icon_confused:
I towed my 90' LWB ranger (4.0, 2WD) on a 16 foot tandem axle trailer behind my 05' ranger (4.0, 4x4) 40 miles to my uncles garage. The truck would keep up with traffic, but I knew the load was back there. Also, it took signifigantly longer to stop too. Stopping and staying in control of the towing truck is a bigger issue than acceleration, and that, a ranger will struggle with, especially if the roads are wet or not paved. If it were me, I would use atleast a full size 1/2 truck (F150, Silverado 1500), if not a 3/4 ton truck.
With trailer brakes it should be fine. Just keep in mind that the trailer weighs more than the truck you're towing it with and drive accordingly. If it's an automatic trans and you plan on doing it often, I highly recommend an upgraded tranny cooler, like, the biggest one you can fit behind the grille. Also, if you like keeping up with traffic, you may want to consider an F-150 or larger.
I definately wouldn't try it without trailer brakes though, that's just asking for disaster.
ok so tranny cooler, trailer brakes. what if im towing it without a trailer
Don't plan on going very fast! All 4 wheels on the ground tends to produce some "interesting" towing dynamics.
Again, if you plan on towing a ranger regulary for longer distances, more than 20 or 30 miles, you should look at a 1/2 ton at least.
what about under 7 miles should i just drive my rig to the trail at that point
If you only driving like 7 miles you may just want to drive it. Since its just a trail rig you may want to try and get farm plates if you can them in your state. They usually let you drive like 150 miles with farm plates.
do i need insurance to get farm plates cuz i dont think i could afford it along with all the cost of my new dd added
Differnt states have differnt rules on what you need to do and the requirerment to get them its just something to look into that could save you a few bucks if it works out. Because getting a trailer and pulling it with another ranger dosent sound like fun for a seven mile trip. Is min coverage realy that bad for that truck??
Usually if it's going to be on the road at all it has to have insurance... I'm even think the Amish around here have to get insurance if they want to drive their tractors on the road (I don't really know, I think I heard it somewhere)...
I would put minimum requirements on it regardless. What if someone pulls out in front of you and you aren't covered? That automatically makes it your fault and you will be up a creek without paddles on that one, not to mention the fines and stuff for driving without insurance.
If your only towing 7 miles, you should be ok. (depending on your towing experience) I wouldn't recommend a first time tower go at it. Make sure you give yourself plenty of room to stop.
If you plan on doing this regularly, like these other guys said, trailer brakes are a must, and a bigger tranny cooler wouldn't hurt. (I would recommend a 1/2 ton pickup but you said, you cant afford insurense)
Considering a F150 is cheaper to insure then a Ranger, I would say that getting a half ton isn't completely out of the ball park.
If you tow it on the ground, make sure you take the rear drive shaft off.
my budget is really tight i make around $13000 a year im still going to school as well i would like to get a f-150 it just needs to have more than 3 seats other than that it can be bone sock
Yea, im a college student. Money gets really tight, alot of penny punching. If you can somehow afford a 1/2 ton, and are going to tow regularly, get one.
