- Mar 21, 2009
Umm i'm a technician at a ford dealership and we have never ever removed a torsion bar to do balljoints on a ranger or f150. The lower control arm isn't going anywhere, the shock holds in in place. If you are that worried about it just support it by the lower control arm.
I understand you are and i'm not knocking you. You know a hell of a lot more than I do. I went to my local dealership and talked to the tech's there. I was told that the proper procedure for replacing ball joints was to remove the torsion bars. It even says on Alldata to remove the torsion bars. What i'm saying is, instead of removing the cv shaft, I removed the torsion bars and I took the lower control arm out from under the truck and replaced the ball joints with the LCA out of the truck.
There no need to actually remove the cv shaft from the vehicle, just front the knuckle and push it to the side. Then its just a snap ring and a hammer away from being out. With removing the torsion bar you have to get the ride height set again and align it, with leaving the lower control arm in place there is no need for an alignment if you are just replacing the lower balljoint.
seriously dude, your 100% wrong!
i have been fixing cars/trucks for over 20 years, i have 8 michigan certs and 6 ASE certs. there is no need to remove the torsion bar to change the ball joints on any ford truck!
i understand what you are saying, but if you do not remove the shock the lower arm can not become "un-loaded". the way I and the other guy described how to do this is 100% correct.
give it up, if you did this your way you did more work then you needed to.
For the hell of it i'm gonna have a peek at the shop manual tomorrow just to see about the torsion bar thing...i'm not saying you're wrong about it. Ford doesn't always say to do things the smart way...
