Just curious, what tire size and gear ratio do you guys who can't cruise 35 mph in OD have?
I have a 2wd with 3.73 gears and 255/60-15 tires and can cruise through town at 35 mph in OD without a problem. The truck gets better mpg at 35 mph in OD than it does in 4th. My clutch locks tight and doesn't slip.
There's no way you can get better mileage cruising in 5th at 35mph, your engine has to work harder to move your truck... Unless you are just coasting most of the time instead of actually driving... Plus, it's bad to run your engine below 1500rpm like that... I'm still in 2nd at 35mph, I'll shift to 3rd if I'm going to be there for a long time (just because my truck has a weird vibration around 3k rpm)
