- Jan 1, 2008
- Denver area
I have a few questions on general maintenance that didn't seem to fit in any one topic area...
The front seal on the rear differential and the rear seal on the transfer case both appear to be leaking a bit. How tough is it to replace these? I replaced the rear diff fluid about 15 months ago and while it was nasty it didn't seem to be super low. So I'm thinking the leak in the diff isn't bad enough to worry about.
How much play should there be in the carrier bearing? I can easily move the drive shaft up and down some so I'm wondering if it should be replaced.
How long do the OEM u-joints usually last? I'm wondering if I should replace them all as preventive maintenance.
Is there a drain plug for the transfer case? I didn't see one so I guess that means I have to suck the fluid out the fill hole, correct?
It seems like the general recommendation is to not repair the OEM LSD and instead replace it with an aftermarket locking diff. Sound right?
There is a bit of slop in the steering wheel. Is that usually worn ball joints?
The head liner is falling out. How the heck do you fix that??
