- Nov 25, 2008
- Washington
I picked up a full width HP dana 44 out of a 79 f150 for $80 today. It has 3.54 gears and I only got the long side shaft assembly for now, the guy is looking for the short side and I SHOULD have it soon. its needs everything from the knuckles out, since he used the knuckle/brakes on his early bronco to get discs. So my plan is to grab some chevy flat tops, run a F150 brake/hub assembly and for now try to find a set of used gears for cheap. I want to keep this as cheap as possible. I'm unemployed and spending my tax refund to pay for all this, so that means using junk yard parts and getting hooked up. I can get a complete ttb dana 44 from a buddies 84 bronco full size since he is also sasing his rig. Now my question is, just to reassure me, will the dana 44 ttb spindles, brakes, hubs work on the chevy knuckles since the spindles are both 6 bolt (I think?) and I get the ford 5 on 5.5. It seems like it will work and it also seems like the gears might work in my housing as well since their both rev cut. I just hope this will all work together, cause if it does my sas/axle build will only cost me around $500. any help, reassurance, and/or advice will be appreciated.
