t case question
88gt
Boosted (Not Stock)
central VA
im replacing my pulse hubs with avm manuals. when i flip the switch intpo 4 wheel hi or low...will is still go without the vacuum hub assembly attached? this is on a 99 ranger.3.0 auto
with AVM hubs. even though you have manual hubs on. Turning the knob still engages the transfer case.
for example, you could put the t-case in low range and leave your hubs unlocked and you'll effectively have a low range 2wd (the front axles will still spin...but you will be able to turn on high traction surfaces without binding the transfer case).
alright, that what i wanted to know thank you both
