- Feb 10, 2009
- Age
- 35
- Sanford, NC
Is there times were it squeaks and then it doesn't?
Addition to the tech page maybe?
On another note replacing the cam syncro is VERY easy. It is located on the back left side of the block if you are looking at the front of the truck. it makes it easyer to axcess if you remove the coil pack. then i if i recall there i 2 bolts holding the sensor on the syncro and one hold down bolt holding the syncro in just like a dist. Just be shure to mark the position of the syncro and when you install the new one just line it back up properly and you should be able to drive away in no time. It took me less then 30 min to replace mine and i had never done it before.
Hope this helps you toms994x4
Wouldn't you have to go to 10 degrees atdc? Than position syncro 38 degrees counterclockwise with the engine?
