whats the widest tire i can get on a stock 08 ranger wheel
DangerRanger08
Fresno, CA/ Porterville/CA
i have an 08 ranger with a 3" lift all around. Im going to be running stock rims because i do not have the money at this moment to buy new ones. i am wondering what is the widest tire i can fit on the stock rim. i've looked everywhere and no luck but maybe somebody could help me out here.
Thanks
Kevin
10.50" is the widest you'll be able to go without having wear issues with the tires, but if you don't mind replacing tires more often then you could run a 12.50" and that would be pushing it.
You can run 12.50s no prob but BEWARE of tread wear, i believe the center will wear out the fasted with a 12.50 on a stock rim, but you might be able to regulate how much air you put into them, like not running max psi, maybe like 25-30 psi.
93ranger4x4
93ranger4x4
even if you air down your still going to have wear problems i would stay with a tire no wider than 10.50"
not the best of pics by a long shot, but here is what a set of 33x12.50 bfg At wore like on 15x7 rims.
if you notice these are the pre ko's so they are up in age(atleast 10 years old) and I have no clue how many miles were put on them.
the tire in the "back" I would say was the power tire. and your can see the slight diffrence in wear down the center....
