How much does a 5.0 weigh vs. 2.3Turbo???
fixizin
FoMoCo is forcing me to buy a 'yota
⭐Supporting Member
Fort Lauderdale
FL - USA
Other
FLEX-fuel, baby!
Drive
0" bone stock
P235/75R15
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
Just wondering about ft-lbs. per lb., you could say. :icon_idea:
Thats a little subjective. Both can cover a pretty good range.
Built/stock? Minor tweaks? Year Range?
*edit:
An all cast Iron 5.0/302 is going to run about 530lbs - ish. You can get them to around 450 with aluminum heads and a aluminum/plastic intake.
A 2.3L is around the 340lbs to my knowledge. it's all cast iron as well, and I know of no real aluminum heads that aren't all out drag race oriented.
All I know is that me and my buddy were really struggling to lift my 2.3, complete with accessories, out of the back of a pickup. It takes 3 to lift and put it on an engine stand.
My 302(avatar) weighs only 50lbs more than the 2.3(non-turbo) that was in there. But I'm also not running A/C or smog, so that sheds a few more pounds off the beast. I'm estimating around 310HP from the motor.(I hope)
Keep 'em coming. I know the 2.3 is a heavy little 4-banger, but I'm sure all that "beef" is a factor in why it's so "bulletproof".
Will it's so-called Duratech replacement achieve the same reputation? Hmmm...
PS: What's an "avatar" 302? :icon_confused:
I think my ranger gained about 100-120 pounds going from 2.3L and 5 speed to small block ford with aluminum heads and Lentech AOD transmission.
D'OH!!... sorry, little slow on the uptake here... thought it was the name of crate engine builder, lol... :blush:
Daaaang Iron Dude, that motor's gonna be too purdy to even put oil in!... the legendary blown-302... with the delightfully slave-cylinder-FREE T5... yummy. :drool:
Oh, it'll have a slave cylinder all right, just the piston style riding on the side. I need to weld up a bracket for this to be possible.
