- Oct 31, 2007
- Age
- 42
- Crawlorado
$300 worth it?
I do wheel this bitch and not at the *#$ing mall and will continue to do so for at least another year or so and I know they(8.8 d35) are plenty durable...but I also know they have limitations and weak points-just like anything else. Im also fabbing up some extended radius arms as to hopefully get more flex out of it. I might just end up ruining a set of stock rad arms...I dont care its a learning process! This is something I would simply like to learn more about and hopefully grab some junkyard jewels for cheap that I can refurbish myself as I collect parts in the mean time. An SAS isnt done over night and in the mean time Im simply researching more about the different setups and how its done.
91
you do what you do and I'll do what I do
i never said you were either. the reason I started this thread was that I know many on here have done it and could help offer advice. advice on what parts to look for and on which trucks which with a little/alot of fab work will keep things as cheap as possible. im not into building the coolest most expensive rig nor can I. But I would like to make my truck more capable down the road and would have as much fun building it as I would wheeling it. when the right time comes I will reap the benefits of full width axles...untill then Ill be on the trail testing the limits of my current setup
