dodge suburban?
Well.... I hate to come in and stir the water, but............. Coming from a Cummins and ASE certified and diesel equipment certified TRS user, yours truley, HEUI injection is by far the most stupid idea ever constructed to be an injection system on a diesel.... Hydaulic Electronic Unit Injection operates by the use of a high pressure oil system to operate a slave cylinder that shoves the diesel fuel through the injector.. I have worked on fords and 'Navistar' diesels and I think Ford actually won when they had thier diesels in medium duty truck in the '80's and '90's.. They should have stuck with it... So.... Personally I own 2 Dodges with Cummins engines in them... My main daily driver is a '94 with 300K miles on it. I get 16 city/ 22 hwy MPG, the engine doesn't consume a drop of oil. The breather tube drips one drop of oil on the ground the size of a dime when it sits overnight. I have some very minor performance work done to it.. Last time it was dyno'd I made 365rwhp/ 785 rwtq, RELIABLY... The other is a '97 with 223k miles on the truck and 10k on the engine and 12k on the trans. It has 15:1 pistons, a cam, some more fuel, and a turbo. I daily drive that as well and it has 700 rwhp, no need to say I only get about 5-12 mpg, but that doesn't consume any oil either, and I drive it to the track and run 12's... The B series Cummins Turbo Diesel is by far the best engine ever to be put in a Light Duty Truck, Duramax/ Isuzu a close second, and im pretty sure I'd put the 6.2/ 6.5 chevy V-8 Diesel ahead of any HEUI powerstroke....
"The only thing that runs good on a powerstroke is the owners mouth." :icon_thumby:
...and as for the Ramburban that is FUCHING AWESOME :headbang: :icon_hornsup: :headbang: :icon_cheers:
So go find a Dodge/Cummins forum to brag on dillweed.:rolleyes:
In mexico they have the 2 door ramchargers which look fucking sweet, but ive never seen that shit before. Up here there are 4 door broncos which is new to me. blew my mind when I saw one tooling around like it was nothing special.
Somethin like this?
http://www.fourdoorbronco.com/
REAL Fords have Powerstrokes. Real Dodges have Cummins. your point?
^^^^:icon_rofl: NOOOOOO!!!! I didn't know that!!!! thanks for pointing it out!
This whole thing is turning into the classic "Ford vs. Chevy"..."Colt vs. S&W"...".45acp vs. 9mm" argument...I give, you win....feel better now?
Actually, this is turning into nobody vs. nobody.... You accused Dodge trucks of being junk and I proved you wrong and said powerstrokes are an ill-designed engine.. That is all DILWEED.. :icon_thumby:
There is one of these running around my area.
sorry , but i would have to go with a CAT , i read an article in off-road about a guy that had a buddy in fords truck r&d department back in 76 , he got his buddy to convince ford to build a one off truck for him , he needed a chase truck for baja , so they took a 76 2WD F-350 , put in a CAT 1126 Diesel and an allison automatic , the truck was insane , i will see if i can find the article
and that white one is like the one i saw in readers rigs
Ill have to go with anything 400CID or bigger that has a 4bbl.
later,
Dustin
woah.... in '76 a diesel 200 horse at the crank was phenomenal.... how was that awesome?
was that sarcasm ?
and it was awesome just because it was a 2WD 1 ton with a CAT diesel , that is what is so great
ok... then i guess you are easily amused, oh well....
if you go on the kragen website and click on truck accessories it comes up with a dodge suv of some sort....any body know what it is?
http://www.partsamerica.com/TruckAccessories.aspx
Dodge built that suv about the same time they had the T-Rex concept!
http://www.flickr.com/photos/28036473@N00/439140834/
I used to be huge into dodge until i discovered the rangers but i think they built that for south America or mexico it was suppose to come over to the states but it never made it. It even had a different name but i can't remeber it.
OOOOOOhhhhhh you hurt my feelings, I am so sad. You PROVED me wrong by "saying" powerstrokes were an ill-designed engine.
Sorry to burst your bubble sunshine, but it's gonna take a little more "proof" than you simply stating it.
You're a Dodge (or Cummins or WTF ever) mechanic so you're biased towards them, and I work at the Superduty truck plant installing engines, so I am biased toward them.....We ain't EVER gonna see eye to eye pal.
considering a 460 big block of the era put out an "anemic" 220 HP with only 360 ft-lbs of torque....ya a 200 HP diesel truck was impressive...especially when you consider the nearly 500ft-lbs the 1100 series could put out.
500ft-lbs is still respectable by todays standards.
If it wasn't for a Government loan, Dodge would not even be in existance in the near future.
http://www.daimlerchryslervehicleproblems.com/
Judging by the signs, Chrysler is definitely going to fall before the American auto industry recovers.
So, see? By this time next year, there probably won't be a Chrysler. Problems already solved.
THAT ENDS THE ARGUMENT!
