Going to look at a Dana 35
Stumpy
Tacoma area, Washington
So there is a guy on craigslist trying to get rid of a D35 that is supposedly locked with 4.56's.
It's already out of the truck so I figured when I go look at it tomorrow I'll pull the pumpkin off to see how it's locked (he said he didn't know) and check the condition of the gears.
Is there a specific ring gear thickness I could measure to see if they actually are 4.56's? What other ways could I identify them?
Look for markings on the ring gear such as 41-9, or 4.56.
You can also count the teeth (should have a 41T ring, 9T pinion)
Yes.....should have either.
Pay close attention to the contact surfaces of the ring gear and pinion. There shouldn't be and pits, etc.
Hopefully it's locked with a lock-rite, aussie, or detroit, etc.....not welded.
Thanks you guys, yeah I really hope it's not welded. That would pretty much kill the deal for me.
I wasn't sure about the markings, I'll be sure to look for those (or just count) :icon_thumby:
If it's welded, and it's a good deal, see if you can get a few more $ off. I have an open carrier I'll give you if you had to swap out a welded one.
Alright... brought her home.
Gears looked good, axle overall was in decent condition. Buuuuuuut it was welded.
Talked him down a bit and walked away with a 4.56 geared D35 front end (minus drivers side caliper & rotor)
For a whopping $150! :icon_bounceblue:
Got a spare set of axle shafts with the deal too.
Good deal even if it is welded.
