- Sep 24, 2007
- Age
- 39
- Long Beach, CA
ahh crap. can you jut run the NB for now? you are running the LC-1 in NB emulate, correct?
With all the new pipeing and different IC your fuel tables will probably be different now also than they were before... It would be a bummer to not have the wideband to tune it back to where it should be. I wonder if there is anyway they will warranty it.
did you remember to switch the MS over to narrowband O2? and if you tuned the MS for the bad TPS, not that it has a good one will the readings be wrong in the MS?
Have you tried making your own boost tester to find these leaks? Pressurizing the system to your desired boost level will allow you to listen for air leaks. Alittle soap and water at all the couplers and clamps, bov, gasket mating surfaces, ect., will help to find them. You'll never find all of them without some sort of device to pressurize and imitate boost. Remember, some leaks will not leak until you’re in boost....
you are using t-bolt clamps, right?
