got cheap tires but....
89DANGERANGER
kentucky
they are 33 x 12.5s can i fit them on a stock 7'' wheel? i still have the stock 7'' wheels from a 99 ranger on my 89 ranger. will they fit
I believe that you need at least a 10" for that... I wouldn't try the 7"
i have 8'' wheels on my bronco with 33s and they do absolutely fine.but i tried a 7'' wheel once and the wheel stuck wayyyy in and the tire was buldging.
They can work but the middle will bulge out and wear in the center, if they were 35's it wouldn't be as big of a deal cause the sidewall could bend enough but not enough sidewall on the 33's.
+1
you dont want to use anything less than 8 inches wide. it can be done but again it'll balloon a ton and have a weird wear pattern
