Homebrew Ranger rear disc brake conversion
V8 Level II
Dec 2008 STOTM Winner, 2008 Truck Of The Year
MTOTM Winner
Boosted (Not Stock)
Michigan
There are various ways to swap Ranger rear drum brakes to discs if one is so inclined. Here is my version:
Before: factory 10" drums
After: SVO 11 1/4" vented rear discs
Conversion Parts:
79~85 Eldorado/Riviera/Toronado rear caliper
84~86 Mustang SVO 11 1/4" vented rear rotor
94~04 Mustang GT front brake hose
Custom fabbed caliper bracket, splash shield and p-brake cable adapter
OK Now for an easier and cheaper version. Grab all the parts from an explorer 8.8.
The FX4 L2 trucks had a 31 spline 8.8 out back. The caliper/backing plate mounting pattern is the same for the 31 spline 8.8 and use the larger bearings.
Only Shitty thing is the explorer park brake system sucks balls.
Yes, I knew about that before I did my conversion. In fact, I did install the Ex rear discs on a friend's Level II. Had to do some custom work on that one for brake lines and parking brakes.
For mine, I wanted to try something a little different and also wanted to avoid the drum parking brakes under the Ex rotors.
A nearly complete set of new Explorer parts is available for around $400 in a kit from Ford Racing. Used junkyard parts would have cost less upfront but would likely have needed to be rebuilt.
For my conversion, I bought the Eldo calipers, SVO rotors new on eBay, got the Mustang hoses used and made the rest from scratch. It cost under $200 for everything which I thought was pretty cheap.
i did a cheap home brew disk swap like that but it involved a crown vic axle. total cost was 100 bucks
i morphed the crown vic brackets to my housing
Rwenzing: That looks great...might do that on my truck some day...but not exactly, of course...unless you start selling kits...haha
And you have a 28 spline 8.8 too.
You should do your write up on that here Mark.
