- Aug 6, 2007
- Age
- 63
The rubber insulator between the blower manifold and the heater fan worked like a charm! (Thank you! Bless you!) Not only did the arcing stop, I now have a functional heater fan again, and THAT'S nice when it's -10 outside . . .
I'm going to have to re-route the intercooler tubing because when I slam the hood shut, the bypass valve sticks open and the truck won't go into more than 1 psi of boost. That's absolutely maddening, but there's nothing else I can think of to do about that problem.
Also, I'm UNABLE to adjust my TPS sensor. It gives me a ridiculously low reading (like 24), then climbs every time I touch the screw--no matter WHICH direction I turn it. I can shut off the truck and try again, but I'm always returning to these really LOW readings.
Now, what's worse, is that I'm getting no info from my O2 sensor. I calibrated it a couple of months ago (and with forced induction, it's supposed to be calibrated every three months), but it's ALSO possible that my electrical problems have fried the controller . . .
Do any of you know how to check for this?
So now I can get the idle down, but it's "hunting" like it does when there's a vacuum leak. My vacuum gauge is reading 19 inches at idle, which is normal for my truck, and I notice that my injectors shut off right away when I take my foot out of the throttle. (This may be due to the TPS issue, as that's the only thing Megasquirt uses the TPS value for.)
I can drive the truck, but it's a little irritating to do so. Also, I'm getting a LOT of vibration through the firewall now because that little bit of rubber I installed essentially connects the blower to the heater fan and allows the engine vibration to pass through.
