d44 & 9" questions
crawlin91
Crawlorado
Ive heard the dana 44 axle is a good sas conversion into a ranger. Id kinda like to do coils up front. I think I read there is a d44 axle that is an exact fit width wise.
What vehicle models and year could i find that under??
Ive also heard of narrowing axles though I dont know what it involves exactly.
would the bolt patterns match 5x5.5? is the d44 the same width as the 9"?
I
saw this ad and would like to know if its worth looking into? worth the price? and will it fit in a ranger relatively easy?
icon_confused:
I have a pair of axles out of a 70's Ford. The front is a High pinion dana 44. It is complete from locking hub to locking hub including discs, brake lines, tie rods, and drag link. I believe it has 4.10's but have not checked. The rear is a matching Ford 9 inch, complete drum to drum. I am asking $500 for the pair or $400 for the D44 and $200 for the 9 inch.
axles that are same width as a ranger would be from a early ford bronco 66-77 if you want discs it would be from a 72-77. they would be dana 44 and 9" same width as each other. some have drum brakes on front so make sure what you are getting is what you want. I got a few sets I'll sale. $300 for drum brake front and 9" rear both complete. $400 for a disc front and 9" rear both complete. Also if you want a posi rear I got them also just add another $100 to the price for the pair. All axles have 3.50 gears. Thanks Nick
are the old f150 axles also the same d44 and 9"
Yes, most pre 1980 F150 axles will be D44 and 9". Look through the tech library, all the info you need will be there.
yeah im looking to make something that can take a beating. strictly for the trails. adams ride does sit nice and wide. I want to put them on another ranger
I found a bunch of good stuff in the tech library that I didnt know was in there.
You can use a radius arm / coil system on a ranger by using the stock c wedges on the axle (some can't be cut off) and flipping the lower coil perch in. The lower coil perch has two holes drilled to bolt into the rad arms. The holes are offset and can be turned inward. 73-79 coil buckets can be welded or bolted on. That way you can run a longer coil etc.
I'll see if I can find the link to the build thread I found this on.
Wagoneer D44s are about the same width as the 8.8 but are set up for leafs. Grind off the wedges and you can buy coil shit from balistics and other fab shops that weld on.
I have a set of early ford long ass radius arms for the D44 if you decided to go the rad arm route. I'll let em go for beer.
'72-'75 EB D44s are drum. Discs were only put on the '76-'77s. There's some chance you may find earlier ones that have been converted to disc though.
Technically it's pre-'84 F-150 axles. The D44/9 can be found as late as '86 in some trucks too. 1980 was just the switchover year to TTB suspension.
If you want something that can take more beating than your D35, D44s aren't the best choice.
The D44 may be somewhat stronger in some areas, but the common weak spot (u-joints) is exactly the same on both (not worth the work to swap IMO). EB D44s are actually weaker with their smaller u-joints.
A D44 swap is a good option if you just want the width however.
Yeah, my '86 F150 has a factory 9". I think one of my '85s did too, the other one had an 8.8. It's just a lot easier to find a pre-'80 F150 with everything you need unless you have access to a lot of parts trucks.
To fix the U-joint problem, you can run the Superjoints(I think thats what Randys R&P calls them) and help take a lot of the beating. I have priced out 'moly axles and these joints for the D44 and will run you around 700 for the set up. I think I will wait and find some 60's though(maybe save the D44&9" for my Explorer). You can only build them to be a strong as a stock 60. Now I understand not everyone can afford or even find 60's, but keep some of this in mind when building a trail truck that is gonna get abused......
Originally Posted by 4x4junkie '72-'75 EB D44s are drum. Discs were only put on the '76-'77s. There's some chance you may find earlier ones that have been converted to disc though
. Discs were an option on trucks from 72-75 My dad has parted out over two dozen of these trucks so we have many parts laying around. 72-75 trucks have a normal style cross over steering setup and have a different pitch on the tierod ends where it goes into the knuckle than a 76-77 style axle. The 76-77 axles a have a wishbone style tierod that does not preform well if the truck is lifted. I have had disc fronts from 72-75 broncos that were not converted some of the trucks I've parted have had under 50K miles and came from the original owner. I will admit discs are much harder to find in those years than the 76-77 style that was standard with discs. But most of all atleast in here in the NE part of the country EB are very hard to find parts for at all. Most of them rusted out 20 years ago and have long been junked.
The bicentennial year brought several key improvements to Ford's sport utility, most notably the addition of long overdue power assisted front disc brakes. The rear brakes were upgraded to 11 x 2.25" drums. The steering box ratio was shortened to 3.8 turns lock-to-lock. The dreaded Y steering linkage was also introduced in 1976 along with a front anti-sway bar. A Special Decor Group comprised of a flat black-finished grille, tape stripe, bright windshield molding, and side window frames and wheel covers was introduced mid-year. 15,256 Broncos rolled off the line in 1976.
http://www.bronco.com/cms/early_bronco_history
1976
Disk brakes were introduced on the front axle, with the option of making them power.
• The rear brakes were upgraded to a larger drum size.
• The Ranger Package was introduced.
• The steering column design was changed.
• The power steering box was given a quicker turning radius, 3.8 turns lock to lock.
• There were 15,300 Wagons produced.
http://wikicars.org/en/Ford_Bronco
No, because it's not any better than a Dana 35. It's not any stronger, and will only flex slightly better.
A Dana 60 would be a good SAS conversion into a Ranger. :icon_welder:
yea but all dana 60 fronts are 8lug. They are also all full width. Lastly a 60front weighs well over double a 44 front, like roughly 500lbs. All of this is great if you are planning on only wheeling the truck or your state has no laws about fender flairs and tires etc. I run nothing but 60s in anything I wheel hard. If you plan is to street drive it a EB dana44 is the best swap if you don't want to get to involved.
will these work without too much of a hassle?
I found a set of axles out of a 78 or 79 bronco setup for rad arms and coils (would this year have stronger axles/ujoints?)
Ford 9", 3.56 gears, drum brakes, complete. I also have a High-Pinion Dana 44 with 3.56 gears, disc brakes, complete. The HP Dana 44 has reverse-cut gears
Im thinking about picking these bad boys up,
I either will narrow the dana 44 and run adaptors for the 8.8 or go full width eventually.
