Headlight question ?
david_h_30170
10+ Year Member
On my 1989 Ranger when I pull the headlights on, the taillights and dash lights dont come on. I can push the headlight switch in between headlights on and parklight position everything works properly. I have replaced headlight switch,and the plug going to headlight switch. I was told it was a bad ground and I have check all the grounds I could find. Has anyone experienced this problem ?
check your fuses (dont just assume they are fine).
if the headlight circuit fuse is blown, the headlights will still work with the switch halfway between park and headlight mode.
I will look at the fuse,thanks for the information.
david did you ever get this issue worked out?? i have a 1990 ranger that does the same thing. any info you have will sure help! thanks
Eric
Really? Now THERE'S one fine and safe design. :rolleyes:
