- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
That's a lot of weight... your rear axle is only rated for 2750lbs (or 3200 if you have the 31 spline axle (FX4)).TwoTrackMind said:My rangR is heavier than most (2500lb front, 3500lb rear), and I found that on 31/1150/15 the rear is good @40psi. The front is still in committee (and out to lunch) but 40 seems too hi yet, next set of tyres Im trying @35psi (except I may go to another size which calls all bets off).
