No 4x4's???? Get real. This post will be all about longtravel 4x4's
i get goose bumps just looking at it
[/QUOTE]yaaaaaaaaaa that is sikkk:icon_hornsup::icon_hornsup::icon_surprised::yahoo::shok:
Here is some of the rear on mine. These are old and will be changing things up again very soon.
F150 leaves and extended shackle.
Shackle flip and stock 4 door explorer leaves.
Shackle flip with Durango leaves.
"soon to come"
Yes these ones are, but they have been modified for the D44 knuckles too. Next set will be different, much different.:icon_welder:
Cut/Turn and extended?
i noticed your brakeline setup. did you run braided line down from near the beam bracket all the way to the caliper. its tough to see but i would think that a short flex on the caliper and a short flex at the bracket would be easier? could you get better pictures of the brake line setup
I had the line and the fittings so that's what I used. Next set of beams will likely have a shorter flex line with hardline between them.
FWIW right now I only have 4 Leak points on both front lines. If I was to go with a hard line and rubber flex lines I would have atleast 4 per side. I've run similar setups for the past 5 years and never had issues with the lines. I can still lock up the fronts and I've got F150 D44 calipers and rotors.
When was the last time you saw a solid axle prerunner? They are rare and are out there, but mose pre-runners favor TTB, TIB and SLA setups.
there is a 85 chev full race truck a few miles from my house. full tube chasis, suspension seats, 600 hp, rad in the rear, no inner box, with a pile of travel, fiberglass sides and fenders, lexan windows, AND solid front axel. This truck has over $40 000 invested, and has been raced all over, trying to find pics for you guys
sorry to bring up an old post but......anyone know who can build long travel 4x4 ibeams? ive been looking for months and so far only came across one company who can do it, autofab. any others you can refer to me? looking to make my ranger mildy jump worthy
mine has maybe 16" or so of lift before the wheels come off the ground.
want to add a 4" suspension lift with the new frame.
Hey boss, did you ever find what you were looking for?
