- Nov 1, 2008
- wayzata mn
nice man! im assuming its not done yet but it looks good!
You don't race that truck do you? Does it have a cage inside as well? I really like what you've done with the roll cage in the back, its like an actual roll bar in the bed. I was thinking of doing something similar since I don't have the cash or skills to do a proper in-cab cage. How much did it cost you? Does it tie in to the frame the length of the cage? Im guessing you also gonna use it for mounting shocks too?
wows!!! alright but pics of shims too??? haha and also great job!!! LOOKS GOOD.. wanna come to vegas and do the same with my trucK??
always to the frame i have seen a few cages pushed though the floor.never thought of the pillars , i have seen this in wrc thats a grand plan.Essentially that would work. The think with building an interior cage is that you want to mount it to the frame. When doing this you essentially rigid mount the body so that it doesn't move and tie the pillars to the cage.
Won't rigid mounting the body increase road noise and vibrations?
i have been inspired by your roll bar . some q s. i have been researching roll protection for years now all ways applied to dirt cars .this is the first time i have looked at doing a truck .the in out set up you are building is what i want to do . my q is when you talk about solid mounting your cab you are removing the rubber and replacing it with some solid puck , for lack of a term? when i was building stock cars we would use a piece of pipe caped with plate and drilled. then bolt this in place of the rubber body mount . is this the same idea , or is there a more high tech method ? in retrospect my methods back in those days don't seem so safe these days .
Haha! Very cool Idea and Props to you for being different! One thing I would try in the future is to have Deaver build you a pack off of your main spring. It will help make the leaf pack progressive and work 100x better. It will allow the spring to pre-load which will help the truck droop out in the bigger holes. Whithout pre-load the truck will pack up. Also when your ready for some shock valving tips let me know! I am more then willing to help make your truck go faster in the ruff. Plus it would be cool to see you pass a guy with those standard everyday off the shelf leaf packs that dont do what they claim. haha!
