- Feb 26, 2008
Is the driveshaft tight? I have seen driveshafts with a tiny bit of slop in the slip yoke vibrate like no other at highway speeds.
Pretty sure it's tight. It has a tiny bit of play but not more than a couple degrees. From what I understand a tiny bit of play is normal.
My '86 was making godawful noise for a while...turned out to be a heat shield on the passenger side that is normally riveted to the cab was loose and rubbed against the tranny.
Is it an automatic? I also had a buzzing/rattling noise in my '88 that ended up being a transmission vent tube rubbing against the side of the trans. Just some things to check...noises like this can be hard to track down.
Ya it's an automatic. I went through the bottom of the truck front to back looking for anything obvious but didn't see anything.
how long ago did you put the lift on? What is your pinion angle?
Not sure exactly, the lift was on the truck when I bought it a year ago. No idea on the pinion angle.
