- Sep 18, 2008
First time owner of a 2000 Mazda B3000 3.0L V6 (which is the ranger of course) flex fuel. It has 104,890K and stock everything. Here are some things I did after purchasing the truck that may help others with performance and running condition.
1 . I found out that the gas peddle and peddle arm inside the truck was plastic. When pushing the peddle to the floor I was only getting 3/4 throttle. Meaning the plastic arm was bent and the cable had lots of slack. I installed a small cable clamp on the cable inside the truck and wala 100% throttle body open with the peddle to the floor. This is something I would not normally check. If other have poor acceleration this may be why; never know.
2. I installed a $40 cleanable air filter with adapter (off ebay) and removed the upper part of the air box leaving the lower to particularly shield the hot engine air from the intake. I plan on cutting and installing the upper part to completely shield the filter and leave it open to the front inside of the truck.
3. Ran 2 containers of fuel injection cleaner 2 times for two full tanks of gas.
4. Replaced the engine oil with 5W-30 full synthetic (and filter)
5. Replace the transmission oil and filter. Note: My tranny was a 4R44E and if you purchase a kit from Autozone get the “short” or “smaller” filter kit. One filter (smaller) is flat on the inlet site and the other filter has a 2.5” circular neck extending down off the inlet side and for a deep transmission NOT the 4R44E.
6. Replace the rear-end gear oil with 75W-90 full synthetic oil.
7. Installed 6 splitfire plugs , not the newer copper standard ones but the actual “Y” type (part number SD10F off ebay at $3 each).
8. Purchased and installed 8MM silicon Ar-Tech Automotive plug wires Part # 6675 (off ebay) for $26 total (included shipping). And they fit like a glove.
9. Replaced the radiator fluid 50/50 Prestone.
10. Bleed the entire brake system of the old nasty brake fluid. Took a fully larger bottle to do this.
Talk about a night and day difference in performance and breaking; runs cooler too! Takes two full days and goggles but worth it. Cheers…
