card board inside a driveshaft?? WTH
Featured Build Threads
pjtoledo
⭐Supporting Member
Toledo Ohio
'98 Mountaineer driveshaft, heavy duty cardboard insert.
that's a new one to me.
vibration dampener maybe?
To dampen sound so the shaft doesn't whine or "sing" with vibrations.
all the above.
closer inspection revealed a part number on the inside.
Ford stamped a part number on a cardboard tube?
......what is it
The cardboard was the actual driveshaft. They encased it in steel to protect it from rocks.
Rocks? I thought it was to protect it from water.
It will help retain moisture so it will fail eventually.
Can you imagine the striped bruise that will leave on someone when you "whop 'em upside the head" with one of those? Much better than wrapping paper tubes.
Upcoming TRS Events
Featured Ranger Based Vehicle
