- May 30, 2024
- Indianapolis, IN
- 2.3L
By speed sensor I mean the speedo cable thing basically like you have. My '97 just uses the two wire sensor that is on the end of a speedo cable but has no cable so I know for a fact that you can go through '97...
ok wait i think im confusing things here. do you mean that yours has the PCM speed sensor built-in to where the speedo cable connects to the trans? Yea, mine is setup like that. If I'm interpreting what you are saying correctly, you are telling me a trans up to 97 model year will work without swapping the tail housing, a direct drop-in?
