Sgtsandman's 2019 STX FX4
The right side panel is now assembled again. Here is a picture of it by itself and then another with the other panel next to it and the vertical dividers temporarily installed. The idea is that when they are not in use, the vertical dividers and the refrigerator slide will come off for easier carry and storage. The deck being in halves is that way for the same reasons. The drawer box itself is pretty much a permanent installation but the deck needs to come out when the bed needs to be used for other things.
Finally, the camera isn't picking up the color properly, there is a bit of grey in the brown. All to better to hide the inevitable dirt and dust that is going to get into the bed.
I installed some seat covers since I have gotten tired of keeping up with keeping the black cloth seats clean.
I got to working on the steering rack replacement today. For those new, or haven't been following along, I have a water intrusion issue into the steering rack. I haven't gotten to the point to see where the water is an issue, but if the weather drops below freezing, the water trapped in the rack freezes and locks the rack so it can not be steered. The only way around it, until you can replace the steering rack, is to let the truck warm up for about 30 minutes so the heat from the engine can thaw the steering rack.
For those who have 4X4, clearance to pull the rack out of the truck is very tight to not enough. Mine is not enough. So, I had to pull the front axle in order to get the steering rack out and install the new one.
All that to remove this
And install this
Been there, done that haha. Its a sucky job for sure. Like I said on the other post. I ended up taking the tie rods off and swinging the steering shaft input around the front of the motor and dropping it out the passenger side. Probably easier than removing the whole axle, spindles and such. I was also able to keep my alignment pretty close by removing the tie rods in 1 peice. The alignment guy said he was surprised how close it was when I told him I had just replaced the whole rack and pinion. And for those of you with a 2020 built after 06/08/2020. Know that they changed the tierod ends after that. They have a shorter wider shaft on the ball joints.
I finally had a chance to inspect the old steering rack for where the water got in.
It looks like the point of failure was the O-ring sealing the section where the belt and gears are housed. The RTV seal between that housing and the motor was very strong and took some effort to break. The seal on the input shaft for the steering column also was intact.
I finished the wiring on the amber lights for the bed of the truck and the shower tent. It was starting to rain, so I didn't feel like fully opening the shower tent up for a picture. But they all work as intended.
And these are the switches for the lights. They are way heavier duty than they need to be as far as amperage but they were the only waterproof ones I could find and I like the protection the switches have in case something falls over on them.
One of the first things I did was get a cap for the bed. This one is a bit more fancy than the one on the 2011. The interior is carpet lined, has front and back LED lights that turn on when the hatch is opened, a roof rack, front slider window that tilts open, pet screen protection, a power port block, and a roof cargo net. Both the lights and the power port block are wired into the start battery.
That's a nice looking truck, big guy. Funny, Iwas talking with a buddy who's got one. His wife wanted it. He wanted something much more like a Ranger. He didn't like the size. He mentioned that now there's even an app for new trucks directing them to places where they could be more easily parked.
I would have preffered a smaller four door as well. But they don't make them anymore.
I got some work done on the house battery system yesterday and today.
Yesterday was running the 4 AWG wire from the truck start battery, to a waterproof circuit breaker, and then back to the bed of the truck. That was a pain in the butt.
Battery connection
Wire routing to the circuit breaker and through the engine bay toward the back of the truck.
The waterproof circuit breaker for the positive line running back to the truck bed. I did forget to take a picture of the negative lead. Not really anything special there. The truck has two big grounding lugs in the driver's side wheel well and another in the same rough location that is inside the engine bay but very difficult to get to. So, the negative to the bed is connected to one of the lugs in the wheel well.
This is where the 4 AWG wire is entering into the bed. The holes were already there. I will need to pick up some grommets to protect the wire. You can also see the 250 amp circuit breaker for the battery power and the anderson plug that will be connecting the 200 watt inverter to the batteries. Yes, the one wire still needs a lug. They are supposed to be in tomorrow.
The inverter and the two 100 amp hour batteries.
Layout work has already started on the shutoff switches, the remaining circuit breakers, anderson plugs, the charger, the fuse block to hook up and run stuff, and the monitor to show system status.
Not much got done that is visually productive. The ignition signal wire got ran up to the fuse box and I did some work on the second board that will house most of the electronics for the charger and the fuse block to actually run things. I need to build a box to house the shut off switched for the batteries and the solar panels first. The back side is just to exposed for my taste and using the base they come with is too clunky and tacky looking for where they are going. And the amperage coming through those would make for bad things if the wrong thing fell over and contacted the posts on the switches.
I will say this and maybe yours does a better job than mine. But once I put the soft topper on after the hard bed cover. I had 2 inverters go out. When I opened them up, you could plainly see corrosion from moisture. Since I moved it to the cab behind the back seat I've had no issues. Again maybe yours does a better job than mine.
I will keep it in mind. Supposedly, this one is designed to be on boats, with built in GFCI. We'll see. I have been trying to get gear with some kind of water resistant or waterproof rating, because stuff happens. Even though it's all being buried in the front of the bed, away from the tailgate.
Yeah I had mine in the front driver's side of the bed. The hard cover had a thick foam insert for the drop down at the front of the bed. The flap on my soft topper seems to let moisture through. That's the only assumption I have. Both I burnt up were GFCI protected. It corroded the circuit boards inside. I went through 2 before I moved it. I also bought a Victron this last time. The first 2 were take offs so little lost. I was a little more concerned when I had to come out of pocket haha. I know the Renogy stuff isn't cheap as well so I just wanted to share my concern and experience.
If need be, I'll move the inverter into the cab. Running power cable to it in the cab would not be fun.
So far, the bed has been dry ever since I used some real thick window foam on the back corners. The front has not appeared to be an issue for me, even during storms. Maybe I've just been lucky.
