- Jan 6, 2002
- Pittsburgh
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Total Lift
- 1.5"
- Tire Size
- 265/70-17
- My credo
- "220, 221, whatever it takes."
Yesterday morning I went down to the basement for something and there was water on the floor near the water heater.
****, now I have to get a water heater. Further investigation revealed that the pressure relief valve was leaking.
So at least I saved $500.
Conveniently the plastic pipe I attached to it cracked at the top, probably from the heat, so water was running down the outside of the pipe and onto the floor instead of the floor drain where the pipe was aimed.
Shut the water off to the heater when I left for work, pick up a new valve at Home Depot at lunch, replaced it when I got home.
Disclaimer: I am by no means a plumber but I know a little bit of stuff.
