Baffling electrical issue please help
IIRC all of the fusible links are on the passenger side inner fender.
Not positive... but I'd bet it's close to the EEC relay
Big update
I found this thread diagnosing a very similar issue and it led to me bench testing the eec relay and it is bad. I also tested the red wire between the eec relay and the pump relay and it seems like our fusible link is good.
Now to find a parts store that is open, will update in a bit.
Edit because I hit post by accident lmao
You said in previous posts... the other relays tested as expected...
Doesn't matter... we would have been there in the next step.
Hopefully it fixes your problem.
And your link don't work... at least for me.
But we likely captured enough to help the next member with a problem.
If the relay doesnt fix it its very likely the ECM. That can absolutly kill pump and injector function...as well as do all sorts of other odd shit.
Yeah good call.
I sure did, that's my bad
It fixed it!
I'm not sure if the relay went bad and burned up the pump or vice versa, but I'm gonna sanity check the old pump to make sure thats actually bad tomorrow lol
But either way we got a runner, thanks yall
Also I found a Haynes manual for the truck when I was at AutoZone which is very cool and would have been super helpful like 5 hours ago
It fixed it!
Good deal...
There really is no direct link between the two components... hard to believe one took out the other.
Strange to have two failures at one but it could happen.
Logically you wouldn't think so, but that shit happens to me all the time...
It fixed it!
Great job, glad u got her working. Nothing like success. 👍
Upcoming TRS Events
