I installed two waterproof switches for the lights in the Softopper and the shower tent. One for the white lights and one for the amber lights. The wiring for the shower tent was run along the canvas cage and into the bed of the truck after wrapping the wires in loom and wrapping the loom in electrical tape. The wires for some of the lights have been extended and ran so they all meet in the same general location and were marked to which type of light they are attached to. I pretty much ran out of day light at that point. So cleaned up everything for the night. The next step is to connect the lights to their respective switches and grounds and connect the switches to power. Power is already fused at the battery since I'm using the existing power that supplies the Leer cap lights when it is mounted on the truck.
Soooo, I may have overdone it…
I finally pulled the seat out of the Missing Linc (87 2.9 5sp short short). I couldn’t find a replacement cushion, and before I started trying to cannibalize a passenger cushion into the driver’s cushion, etc., I wanted to see what I was dealing with.
Remember, it was a donor from a 93; I wish I had noted the miles. The cushion was totally chewed away in the back left corner where you slide in and out as you’re getting in and out of the truck.
The rest of the cushion seemed to be in decent shape, except the foam was pushed through the wire support maybe as much as a half an inch. The metal frame of the seat itself, and the tracks, were in excellent condition. The seat was tilting towards the door, and, to my horror, I found a little bit of rust around that left rear bolt area. Nothing too bad, but it was sagging, especially when you consider my fat ass bouncing up and down on it.
I followed @scotts90ranger ’s excellent advice and I cut a piece of carpet to put under the cushion. Fuzzy side up, I cut my scrap carpet fairly precisely with tin snips so it overlaps the frame about a quarter inch in each direction, including the armrest side. I drilled a few holes, and I probably put about a dozen zip ties around it to hold it in place.
I had compiled an assortment of softer and firmer foam over the decades, and I also bought a sofa seat cushion foam from Hobby Lobby. After inspecting the seat foam, I cut and placed dense foam (stadium seats from five below), and I took just a little bit foam out of the existing cushion, so it would nest right into that failed corner. Think what Lego blocks look like. I drilled some holes and zip tied the various pieces together while also gluing them together with E 6000, and I ran a few zip thighs through the existing seat, cushion, and edges of the repair blocks to hold them in place. I’m gambling that the seat cover, which is not damaged, will hold it all together once it’s fully assembled.
Here’s where I may have messed up. I used more of the stadium seat material, which is about 3/4 of an inch thick, across the entire sitting area of the cushion. Well, when I got it back together, between that and the carpet, it’s like sitting on a booster seat. I’m looking out just below the sun visor in the up position. But a couple thoughts on that.
Like anything, once you take something apart carefully and put it back together, you can take it apart and put it back together in 10% of the time. I think I could remove that seat, strip the covers off and pull out that extra stadium seating across the fanny, and have it back in the trunk in 30 or 45 minutes. But…
As bad as the seat was, I really didn’t care as I was driving down the road. But as I recently related, the ongoing problem with my elbow and my hand, may have been caused by, and is certainly irritated by, having too much weight on my elbow/arm on the armrest. So part of the repair was just a normal repair, and the part of the repair was to make it firmer and taller to take a load off my arm on the armrest. I haven’t tested driven it yet, but I’m already planning on doing that, removing the fanny foam.
As regards the rot in the floor, it’s not total cancer, but enough to weaken that spot where the bolt connects and it sits down maybe 1/2-3/4”. I don’t have time to do a proper patch right now. So - wait for it - I wire brushed the area, and then I put an extremely thick coating of rustoleum all over it, and worked it in really well with a short bristle brush. I didn’t paint it, I coated it. Btw, very bright, carnival red, he can’t see it anyway Then I cut the web out of one of my scrap pieces of the 4 inch aluminum channel, resulting in a flat plate (about 3/16”) that was about 3 1/2 inches by maybe 7 inches (I never measured it). On the bolt end, it rests against the solid floor where it rises up on three sides of the bolt. On the door side, I cut it so that it’s resting on solid metal out where the door gasket sits, and it rests on top of the bolt for the seatbelt, which is very solid. I used a longer bolt, and an and a big washer and nut on the bottom, and it’s solid as a rock and the seat is straight now.
The story continues: When I put the custom seat covers over the original seats, I fixed up the armrest which was leaning down like they all do. I built a custom backing plate between the armrest and the side of the seat, and I made an aluminum spacer to put under the head of the bolt that holds it in place. Well, when I was putting this back together, I modified that spacer. Then, when I was trying to take the edges off on the belt sander, it caught funny and went flying across the shed of miracles. I know where it is within two or 3 feet, so it should only take a month or two to excavate that far and reclaim it. I’m starting that today. It’s part of the Lord‘s plan to motivate me to clean up the mess.
I’ll have more pictures when I get the armrest back together. After a break, I forgot to bring my phone outside with me, and my legs were hurting so bad I didn’t fetch it and get pictures of the repair progressing. Sorry about that. I’ll have more when I do the armrest, and I’ll probably pull the extra foam out.
As predicted, I was able to get the seat out, apart, and back in in less than 60 minutes. That was after two hours of cleaning up around my bandsaw and belt sander, where there was a decade of poor health little drop-and-gos and dust, to find the bolt that holds the arm rest in. But I was successful and, man, am I happy that mess got cleaned up. I found all kinds of things I was looking for.
Here’s the bolt with my custom aluminum washer/spacer:
And here’s the seat pad with my overkill foam repair resulting in the booster seat
I took out all of the foam, except what I needed to do to restore that eat-up corner, where you slide in, and then I just put one additional heavy foam strip (not in pic) to hold that corner together, and a few more zip ties:
With the repair and leveling where it attaches to the floor, and carpet on top of the springs, with just this corner repair, it’s damn near perfect. 😁
The armrest has a cover when I got the covers for the seats. I had put a dense foam on top of it under that cover because of my elbow issues, but it’s still too hard. In the meantime, I had a piece of about 8 x 12 x 3“ thick soft foam held on by a bungee cord, and that worked pretty well, if I also wore my elbow brace. So I just zip tied a piece of about 2 inch foam on top of the cover before I put the seat cover over it. Feels okay. It’s a temp, but I’m going to ride around with that a little bit and see if it does the trick. I’m sure they’ll be minor modifications, but I only want to redo it once.
And whatever I end up with that, it will be the template for fixing up the Road Ranger seat a little before Carlisle Truck Nationals. And when I get a free moment, I know pretty funny, I’ll probably also add some padding to Big Red’s seat (F250).
@scotts90ranger , you must know I was kidding about the compliment. I would’ve never thought of putting anything under the seat, but it worked great. 👍👍👍
I'm speaking to your truck over my priority wireless spy modem.
It said "keep peeing on my cousin buddy... you haven't seen anything yet".
Ain't neva gonna stop the stream 😘
Got a badly needed wheel alignment yesterday in preparation for a trip today (and other trips later). The potholes that resulted from the unusually harsh winter here pounded the front end into having a bit of toe-out. I can feel the difference the fresh alignment makes. The annoying part is that I had just had an alignment done in December.
I make every attempt to avoid potholes and problem manholes in pavement, but they can be invisible or hidden in shadows.
Drove about 300 miles today into North Carolina on the fresh alignment for a "foodie" run, which involved going to places some distance away that sell different types of food I don't normally find around here. One stop was a fishery. Another was a grocery store well known for making its own sausage, potato salad, preserves, and other such items. Fun trip, just got back.
I got most of the wire run for the amber lights today (testing as I went since there was some slicing and butt connectors). I just need to pick up some more connectors on the way home from work tomorrow. Since the overland equipment gets removed for the winter, I need the wiring to have connectors so I can more easily assemble and disassemble everything as quickly and easily as possible.
I'll be doing the same with the house battery system when I get to installing that. It complicates things, but is necessary and better to do it now, while I'm running the wire, than later when I'm trying to get everything put away. Especially the high amperage stuff.
I got the wiring figured out and completed for the amber lights in the bed of the 2019. That should make the wiring for the white light easier, especially since there will be 8 less wires to worry about which lights they belong to.
Nice! Much easier than holding a flashlight.
Yes! Even a headlamp gets old after a while. Since I have SAR training this weekend, and the 2011 is still not back on the road, I figured getting the amber lights working was more important than the white ones. Less bugs getting attracted.
That hood my father in-law bought and we had installed a few weeks back finally got done with paint and stuff so we installed the sprayers and the water lines so his truck is done.
And I finally got new tires on those black 17 inch vision wheels I got used for 400 bucks, a month or two back. I got wrangler territory at s in the stock 255/70/17 size so I still get good gas mileage. Unfortunately, I didn't take any pics
Crashed a show and shine;
And started driving lessons.
Just circled the yard a few times, she was in awe watching out the windows and everything. Probably pretty neat as opposed to watching the seat back and ceiling like normal when she is in a vehicle.
High pressure in-tank conversion and new fuel lines. More to do, but it's raining. :annoyed:
