- Oct 9, 2009
- Midwest City
- State - Country
- OK - USA
- Drive
- 2WD
So, I read anarticle on my phone on MAF testing. Stated if you pull the plug while warm and idling, the engine should die. DId that today, pulled plug on warm idling engine. NO CHANGE. Nothing. Sat there purring like a kitten. Hmmmm.....
Read another saying if you remove the oil filler cap while idling and place a napkin over the opening, it should try and suck the napkin in. Or puff it out if the PCV system is plugged. Once again, BIG NOTHING. Didn't suck it in, didn't puff it out. NOTHING. So, I had a threaded crankcase breather on my grudge shelf. Put it on, revved the engine, VROOM, just like always.
Drove it to work after doing both of the above. Perfectly fine, Filled the tank at the half mark yesterday, checked mileage. 20.55 mpg. On a 3.0 Ranger with 4.10 gears.
What gives here? How is my truck even running. The o2 sensors are 28 years old and have 209,000 miles on them. I'm certain they are bad, but it still runs just perfectly fine. 20.55 mpg on a 3.0 Ranger is actually outstanding.
Is my truick haunted?
