Finished mounting and wiring up the dual wideband in my V8 truck today. Hooked it all up to the Telorvek panel behind the seat. I still have to run the 4 pin communication cable and MAP hose under the vinyl flooring. I also need to mount the dual readout gauge under the dash.
I also finished installing all of the pain in my arse header bolts I bought. They're a c-clip design and my header primaries are so tight to the bolts that I had to custom fit all of the locking parts to each bolt. I will cuss myself in a major way when they have to come out someday. The allen head on the end of the bolts make them extremely nice to tighten up though.
The cult grows.
Bed repairs on the deck of the 2011's bed are finished. Steel sheet should be in tomorrow for me to get the front bulhead repaired. Hopefully, I can get it all done in one evening after work and get the bed back on the truck.
A day late and a dollar short, but a trick I’ve used from time to time. I repurpose everything. Mostly because I’m cheap, and a lot of times because I just think it’s cool or funny (like Scary Baby).
Down here, on any given day, you can find old gas grills for free if you just go get them. As cheap as the cheap ones are, the stainless steel ones are an incredibly good source of stainless sheet metal for making panels and patches. Let your imagination run.
And ditto on the black ones. The panels on the black ones are not powder coated. They have baked on enamel most of the time. The challenge with them is you pretty much have to use them as you find them, because if you bend them, you’ll crack that surface. But if you’re careful how you cut them and drill them, they’re more incognito than putting on a stainless patch on this or that.
And back to the stainless ones, you can drill them, beat them, bend them, and while the metal might be thin, it’s a very good grade of stainless. And then always my favorite, like I do with the Aluminum toolboxes, if I have a particular shape I want like a corner piece, you can cut it out for making gauge mounts or switch mounts or who knows what.
And did I mention free for pick up?
Hope it helps.
Well, the front bulkhead repairs are done. Because the dumpster for the roofers might get dropped off tomorrow, I had to slap the bed on the truck so I could get it out of the driveway. It will need to come off again so I can paint the repair. I'm just using whatever paint I have on the shelf. I'm more worried about protecting the new steel from rust than making it look nice. In the mean time, the steel does atleast have some primer on it.
Hope it helps.
Because of the corrugated deck and width of the repair on the front, I'm not sure a grill would be the best choice. There could have been a couple small sections that it would have been handy.
Well, Choptop got new steering linkage today. I bought new inner and outer tie rods plus the adjustment sleeves awhile ago but finally got around to knocking it out. Popped the old ones out in one big piece, I’ll deal with that later. Put the new stuff in and got it aligned as good as I could for now. See if this helps anything.
I also swapped the front tires side to side since they’re wearing funny because I still need to do something about front springs and axle pivot brackets. One step at a time though. I need the shop done before I get into the brackets and we are just not going to talk about the springs right now.
I hung white and amber LED light strips in the Softopper and shower tent. Maybe I can get the wire run tomorrow.
Soooo, I may have overdone it…
I finally pulled the seat out of the Missing Linc (87 2.9 5sp short short). I couldn’t find a replacement cushion, and before I started trying to cannibalize a passenger cushion into the driver’s cushion, etc., I wanted to see what I was dealing with.
Remember, it was a donor from a 93; I wish I had noted the miles. The cushion was totally chewed away in the back left corner where you slide in and out as you’re getting in and out of the truck.
The rest of the cushion seemed to be in decent shape, except the foam was pushed through the wire support maybe as much as a half an inch. The metal frame of the seat itself, and the tracks, were in excellent condition. The seat was tilting towards the door, and, to my horror, I found a little bit of rust around that left rear bolt area. Nothing too bad, but it was sagging, especially when you consider my fat ass bouncing up and down on it.
I followed @scotts90ranger ’s excellent advice and I cut a piece of carpet to put under the cushion. Fuzzy side up, I cut my scrap carpet fairly precisely with tin snips so it overlaps the frame about a quarter inch in each direction, including the armrest side. I drilled a few holes, and I probably put about a dozen zip ties around it to hold it in place.
I had compiled an assortment of softer and firmer foam over the decades, and I also bought a sofa seat cushion foam from Hobby Lobby. After inspecting the seat foam, I cut and placed dense foam (stadium seats from five below), and I took just a little bit foam out of the existing cushion, so it would nest right into that failed corner. Think what Lego blocks look like. I drilled some holes and zip tied the various pieces together while also gluing them together with E 6000, and I ran a few zip thighs through the existing seat, cushion, and edges of the repair blocks to hold them in place. I’m gambling that the seat cover, which is not damaged, will hold it all together once it’s fully assembled.
Here’s where I may have messed up. I used more of the stadium seat material, which is about 3/4 of an inch thick, across the entire sitting area of the cushion. Well, when I got it back together, between that and the carpet, it’s like sitting on a booster seat. I’m looking out just below the sun visor in the up position. But a couple thoughts on that.
Like anything, once you take something apart carefully and put it back together, you can take it apart and put it back together in 10% of the time. I think I could remove that seat, strip the covers off and pull out that extra stadium seating across the fanny, and have it back in the trunk in 30 or 45 minutes. But…
As bad as the seat was, I really didn’t care as I was driving down the road. But as I recently related, the ongoing problem with my elbow and my hand, may have been caused by, and is certainly irritated by, having too much weight on my elbow/arm on the armrest. So part of the repair was just a normal repair, and the part of the repair was to make it firmer and taller to take a load off my arm on the armrest. I haven’t tested driven it yet, but I’m already planning on doing that, removing the fanny foam.
As regards the rot in the floor, it’s not total cancer, but enough to weaken that spot where the bolt connects and it sits down maybe 1/2-3/4”. I don’t have time to do a proper patch right now. So - wait for it - I wire brushed the area, and then I put an extremely thick coating of rustoleum all over it, and worked it in really well with a short bristle brush. I didn’t paint it, I coated it. Btw, very bright, carnival red, he can’t see it anyway Then I cut the web out of one of my scrap pieces of the 4 inch aluminum channel, resulting in a flat plate (about 3/16”) that was about 3 1/2 inches by maybe 7 inches (I never measured it). On the bolt end, it rests against the solid floor where it rises up on three sides of the bolt. On the door side, I cut it so that it’s resting on solid metal out where the door gasket sits, and it rests on top of the bolt for the seatbelt, which is very solid. I used a longer bolt, and an and a big washer and nut on the bottom, and it’s solid as a rock and the seat is straight now.
The story continues: When I put the custom seat covers over the original seats, I fixed up the armrest which was leaning down like they all do. I built a custom backing plate between the armrest and the side of the seat, and I made an aluminum spacer to put under the head of the bolt that holds it in place. Well, when I was putting this back together, I modified that spacer. Then, when I was trying to take the edges off on the belt sander, it caught funny and went flying across the shed of miracles. I know where it is within two or 3 feet, so it should only take a month or two to excavate that far and reclaim it. I’m starting that today. It’s part of the Lord‘s plan to motivate me to clean up the mess.
I’ll have more pictures when I get the armrest back together. After a break, I forgot to bring my phone outside with me, and my legs were hurting so bad I didn’t fetch it and get pictures of the repair progressing. Sorry about that. I’ll have more when I do the armrest, and I’ll probably pull the extra foam out.
I meant carpet pad, not carpet, but carpet over the wires to push up isn't a bad idea either...
Hmmmm….
Okay, I withdraw my praise on that and limit it to the tachometer dash cluster (which I love). I’ll be more careful with compliments in the future…..
A few day ago i did a coolant system flush, and put in the traditional green coolant with water added. Same ways I always did my 94 3.0 5spd ranger.
Have been looking over the entire truck this month for my move. Im returning to San diego, I will be driving 800 miles next week..gotta make sure this 97 3.0 5spd ranger is going to get there safely.
Bled alllllll over it. Like friggin everywhere.
Thanks, truck! 😀
I'm speaking to your truck over my priority wireless spy modem.
It said "keep peeing on my cousin buddy... you haven't seen anything yet".
Upcoming TRS Events
Featured Ranger Based Vehicle
