Sgtsandman's 2011 XLT
I hadn't heard of any replacement covers like that till Katzkin. They only stock the newest models. Everything else is take it to the shop and have it done.
I looked at leather covers too, but wasn't completely convinced that they would fit. That's why I bought two complete leather bucket seats for a hundred dollars. They were much more comfortable than Ranger seats anyway.
Ok, vehicle update time. As some of you may know, I've been having fuel pump issues. First in December, when the original fuel pump took and dump and just recently with the salvaged OEM pump that another member was kind enough to send me since aftermarket pumps have a poor reliability reputation. I had known there was some rust issues in the normal spot in the forward, passenger side of the bed and had noted in December that it had gotten worse along with a couple ofther spots that had shown up, but it was too cold to deal with it then and I was dealing with the other vehicles having issues at the time as well. So, I had replaced the pump and slapped the truck back together. I would worry about the rust problems another day.
Well, the "another day" has arrived since the replacement pump has failed. I already had a Carter pump up in the loft and a repair panel in the garage. So. I might as well get to it.
First the pump. For those who don't know, the bed has to be pulled or the fuel tank dropped. With a Ford Ranger, it is infinitely easier to pull the bed.
So you can access the pump here.
Since aftermarket pumps have a poor reputation for reliability. I made myself an access opening so I don't have to pull the bed again. Who knows, I might not even need to pull the cap anymore either, which would be handy.
Now for the rust issues. There are several.
First mounting hole back from the forward bulkhead
Second hole back from the forward bulkhead
First stringer back from the forward bulkhead
Second stringer back from the forward bulkhead
Progress so far on a patch for the front mount hole. I also have some pieces of steel angle for under the floor. I'm waiting on Metals Supermarket to fill an order for some pieces of steel sheet to repair the front bulkhead.
Since this is in and under the bed of the truck, I'm looking for function over beauty. Plus, the repairs are going to be under the truck or under a wooden platform I keep in the bed of the truck. So, the idea is to fabriate the pieces, paint them, slather them in acrylic RTV and to bolt and use steel pop rivets to secure them in place. I haven't come up with a solution to repair the stringers yet. I know one member some years back had found some generic ones with no holes that they used to replace theirs, but I have not been able to find them with an internet search.
The aim at the moment is to get the truck back on the road and since the problem areas are not over the fuel tank, I should be able to patch them at leisure later on with the bed on the truck.
Part of the reason for the push to get it back on the road is that I'm racking a lot of miles on the 2019 because of my work commute and another is that the roofers are going to be working on the roof soon. So the driveway needs to be cleared so they can put a dumpster in it.
Ever consider buying a UPULL junkyard bed?
Maybe in the future. It would have to be from something down south. Anything here would be just as bad, if not worse. In any case, The driver's door bottom is rotted out and needs replaced, especially after it got bent due to inattention on my part. So, sooner or later, the truck is going to need a paint job. I'll probably think about a new to me bed then.
Only thing I've done different with the fuel pump patch is make it so the bolts fall in the hollows. That was on a B2.
Most of them are. It was an oversite on my part for the one side where they aren't. The patch was already cut at that point and I didn't want to redo it and waste a piece of metal.
Holy monkeys, my '90 that's been outside for a solid 2 months in the 28 years I've had it has less rust than yours that's lived less life than that... my '97 is new looking compared to that! I commend you for your efforts...
Shoot, mine was under a plastic bed liner. So just used some crappy flat brackets to reinstall the metal on my 98. Hit it with some good old Rustoleum and let it ride. You guys took way more pride or at least had more skill than I did back then. Haha
I have the exact same rust, in the exact same places.
They needed to recall the last few years of the Ranger over rust like Toyota did. Same metal supplier and same frame maker as Toyota.
Toyota issued the recall, Ford did not.
Theres a lot of problems with the 2010/2011s. I'm still not sure if they're worth buying and I've had one since 2020.
For stringers, do a search for “galvanized hat channel”.
Years ago I found the exact size needed, but sold the truck.
Thank you!
Part of the problem is all the road salt and the brine solution PA uses on it's roads (more the brine than the salt).
The frame is in near perfect condition because I hose the underside of the truck with fluid film. There is some surface rust, but otherwise is solid. The sheet metal, on the other hand, not so much. The cab is better but needs some attention. Like @PetroleumJunkie412 , rust on the bottom of the doors and the bed rust have been the big problems. My 1998 was much better with the bed rust, though the tailgate on the 2011 has faired much, much better than the 1998 did and lower door rot was much less of a problem.
My vehicles rarely get stored inside and do see a lot of road time in the winter, especially now with the 45 minute to hour commute I do now. Even before, I was out before the snow plows in the morning. So, I'm sure that didn't help things.
Kind of no choice. It's either that or have a truck payment that never ends as you switch vehicles because of body rot. It's cheaper to repair and maintain what you have. Plus, with all the integrated electronics they are throwing into vehicles now, I'll never buy a new vehicle.
Hell, with the electronic steering rack in the 2019 and the 2014 Escape, if you can't start the vehicle, the steering is locked. There is no manual steering in the thing.
Well, the deck repairs are done. It was dark when I finished. So, pictures tomorrow. I should get a call from Metals Supermarket tomorrow about picking of the steel sheel I ordered to repair the front bulkhead. If all goes well, I can permanently install the bed on the truck and clear the driveway for the roofers. If not, it will get tacked on so the truck can be moved for the same reason. I have stuff I can start installing on the 2019 for a house battery system anyway, while not ideal, I can do that on the street.
