- May 15, 2020
- Age
- 71
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- Vehicle
- Ford Ranger
- 4.0L
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
That's where the leak is. One thought; you do have the reservoir on that side of the check valve. Right? Between check valve and AC controls.
Yes. When I first had the problem, before I bought the smoke machine, I swapped out the sphere which had been damaged by rubbing the belt, and I put in one of the soup cans like you find on there 80s and 70s full-size Fords like my Towncars. I’m guessing it’s 2 to 3 times the volume of the little sphere. That improved it a lot, but that didn’t do it, which is why I finally got the smoke machine and found a real leaks.
When I had a similar problem on the F250 after putting in a new belt driven vacuum pump, and I put the smoke machine on it, I had a problem up by the firewall, but smoke came out from under the dashboard like the dashboard was on fire. I chased down a little bit of it, but the heat and air was working fine, so I never really pulled all those guts out.
