stuck cooling fan clutch removal
codger
5+ Year Member
Group W bench, Columbus, Oh.
I used to do nothing before 6:30 am, now it takes all day.
2002 Ranger XLT 4.0L 4WD ~240K miles
70 YO guy with limited funds running out of options. I'm wanting to replace the water pump, therm. housing, idler and tensioner pulleys, and serp. belt. The first step is to remove the clutch & fan but it's stuck on there pretty good. I got the 36mm tool for the clutch and made a tool to hold the pump pulley. So much for the easy part. I've tried holding the pump pulley still and beating on the 36mm wrench with a hammer, even after spraying down with PB Blaster. Only option I can see is to remove the radiator to get enough room to remove the water pump/clutch/fan as a unit. Will this work? Also, since this means I may need to replace the fan clutch, and I see listings for counter clockwise (reverse) rotation clutches. If standing in front of the truck, the fan does rotate counter clockwise, so is this what I would need?
Trying to use "clockwise", "counterclockwise" and wondering front view or rear view is confusing as hell to me.
Look at the angle (pitch) of a fan blade; in which direction will it need to go, in order to grab air and push it toward the motor? (i.e.- away from the radiator) That is the direction that the fan rotates.
Since the fan clutch is threaded onto the engine-driven water pump shaft, its "tighten" is against the pump shaft rotation direction, so that the clutch will be kept tight, in normal operation, instead of having rotational forces trying to loosen it.
So to loosen the clutch, turn it in the same direction as the fan's rotation.
That's how I figure out how to change mine, and somehow it works for me.
I just hope that I got all of that right from memory; did I mention that fan clutches are confusing as hell?
I use a blunt drift punch on the clutch flange, and usually a couple light hammer taps in the right direction will loosen the clutch nicely.
Thanks for the reply RobbieD. Yes, you got that all correct. When standing in front of the truck, the fan turns counter clockwise (left) which means it has a right hand thread. these things I already know. What I'm wondering is if this is considered a counter clockwise/reverse rotation clutch. I'm assuming it is since it turns the opposite direction of the crank. I haven't tried a drift punch, so thanks for the idea. I'm sure I can find something around here to use, maybe even something I can rig up on my pneumatic hammer.
i do the drift punch on the large nut too, to break it loose. then the tool if it doesn't just spin off by hand.
i have had the fun of one not wanting to come apart very easily though. i ended up having to pull a bunch of stuff to get it off and put it in the vise. not fun that way
I recently fought one. I had the special wrench and it just widened its jaws. Wrench is currently in the scrap bin. I used a strap wrench to hold the pulley and a big crescent wrench on the nut and just kept trying until it came loose.
Thanks guys. Today I'm going to try to find something long enough and sturdy enough to try the air hammer on it, if I can't get the air hammer in close enough to use its regular attachments. I'm thinking that if I take off the serp. belt there may be room. If the hammer doesn't work, I guess I'll remove the radiator :(. Hopefully that will allow me to get the pump off with the fan and clutch attached.
I started this project over 3 months ago but illness and weather took up a great deal of that time. So, an update and a new problem. After removing the radiator, I was able to get the water pump off with the clutch and fan attached. I clamped the pump in a vise and was able to get the clutch off. I've now got the intake manifold (don't ask), throttle body, therm. housing, water pump, radiator, and alternator all reinstalled. My problem is I somehow broke a couple wires off a connector attached to the intake manifold. Probably while removing the upper radiator hose. It's attached to the right (passenger) side of the manifold (see pic). Do any of you know what these wires go to? There are 2 small wires encased in a heavy rubber coating and I'm thinking it may be easier to run new wires than try to cut off enough of the casing to splice in another connector.
4.0l not my specialty. My guess is left rear stereo speaker.
Plug for the knock sensor I believe. The sensor is under the intake manifold in the valley.
Thank you. I guess that means it isn't the left rear stereo speaker wires. :ROFLMAO: That's too bad, since my radio smoked a couple of years ago and I have no need for the speakers. I guess I'll just go ahead and splice the wires because I have no interest in removing the intake again, though I'm sure the engine would run fine even if I didn't even hook it back up. Thanks again.
Atlas if it doesn’t run well you have someplace to start. 🤷‍♂️
I actually found a male plug at a chain auto parts store that would work with the female Ford plug still on the truck. Got it spliced in and everything reassembled. Tomorrow I plan to refill all the fluids and make sure everything works as it should. I'm pretty confident it will. Found something that really surprised me in the Haynes manual. they actually list a torque spec for attaching the fan clutch to the water pump, 30-100 ft-lbs. So, I figured out a way to do it. I have one of those hand held luggage scales like they sell online that I use to calibrate all my torque wrenches. I just hooked it to a 36mm wrench to tighten the nut. So, it's only taken me 3 1/2 months to do a job that should have taken an afternoon, or weekend at the most. In my defense though, I didn't let it cut into my fishing time. :giggle:
