Evaporator coil remove/repair need video
Pumps often leak at the seams when the fail, or a bad hose or O-ring or damage to the condenser core are the most common problems. The orifice tube should be replaced when the system is serviced or at lease checked and cleaned.
I replaced everything and made the AC work in my Choptop. A number of people think I’m nuts for that in something that I can remove the doors and top, but when it’s like 85* and 2000% humidity with rain and I hit traffic somewhere, it sure is nice to get some cool air blowing at you.
So armed with this info seems, if I want I can remove all these parts without affecting the vehicle? Correct?
If you remove all of it and don't repair or replace the housing, you will not have heat/defrost function to clear your windshield on foggy, rainy days.
Just remember that melted ductwork is also there for your heating system. By 1996, I'm not sure they offered non-AC trucks any more. So you may not be able to find a non-AC housing that fits, such as the one someine pictured up above. I believe that picture is an earlier unit.
They did but they didn't use special non-A/C housings anymore. The 1998 I had, did not have A/C but still had the housing for it. The holes where the tubing came out were either plugged or not cut to allow for the tubing, I can't remember which. But that housing was still in the way for any work I needed to do on that side.
Oh, it's still there. It's just WAAAAY slower with out the A/C system to remove the moisture from the air.
Every time he mentions getting rid of "all of it", I envision him not replacing the housing. That would mean no blower and no way to contain and direct the air.
Thanks. I'm still not sure about the a/c. But to give you an indication, I run my house at 79 in the summer. At 78 I'm reaching for my hoodie.
I guess it's all what you're used to. We heat to 70 in the winter and cool to 72 in the summer. I've been working in my garage all week in a T shirt at 60 degrees.
68 during the summer and just warm enough to not lose feeling in my hands during the winter.
Sorry, I wasn't getting notified of updates to this forum.
I finally opened up the housing to the Evaporator coil. I was surprised how little dirt there was and wondered that it caught on fire.
Unable to remove the bolt up top that connected the aluminum tube to the Evaporator, I hacksawed it off. I removed the Evaporator figuring it to be toast and cleaned out the cavity. If I need to redo the aircon, that's all that will be needed (I hope) along with some o-rings.
Sanity check... I'd like to fill the area where the Evaporator was. Is this a good idea? Was thinking to get some fiberglass insulation with the paper towards the firewall to avoid blowing the glass into the cab. Is this needed? I'd stuff it with rags if I wasn't afraid of another fire.
I wouldn't fill anything except the to seal the holes. Fiberglass in there would just become mouse bedding around here.
No just the holes where the evaporator tubing was. And the melted spots, if you're reusing the old housing.
Luke, I can see through the housing as I removed all the screws holding that together. I can get to the firewall through that housing where the Evaporator used to be. I can see that there's a square hole about 4" square through the firewall. Assume that was for the aircon to be blown into the cab? I wonder if it wouldn't be better to put a piece of plastic or metal over that hole, that would probably be easier than wrapping the housing, which has partly melted, with duct tape. Also, when I removed the Evaporator there was a bright colored fluid that leaked a bit from the removed Evaporator. Do you know what that fluid was?
WAG for the fluid is AC compressor oil. Or antifreeze from a leaking heater core.
I'd be afraid to block that hole. I'd suspect it's either how the fan pulls recirculation air, or how it pushes air to the rest of the ductwork. You'd probably loose more than just AC either way.
AC compresser oil.
