2011 Ranger Front Sway Bar Bushings
sgtsandman
Automotive Technician
TRS 25th Anniversary
Aliquippa
PA - USA
Vehicle
Drive
2.3 EcoBoost
265/70R17
Anything that can go wrong, will go wrong. Plan for it as best you can.
Now I'm remembering why I put off replacing the front sway bar bushings when I replaced everything else. Finding bushings that fit a 34 mm sway bar is nonexistent when searching for ones that fit a 2011 Ford Ranger 4X4 XLT. The biggest offered is 29.5 mm. I confirmed the bar size by measuring the bar several times with a set of dial calipers.
So, perhaps ones from an Explorer or Sport Trac might fit since they are a heavier vehicle than a Ranger. Any idea on what years to look at that may have a sway bar this big?
try 2001.
I had a front bar from a 2001 Sport Track that was about 1-5/16" damn thing was waaaay to stiff for me.
I think they went to that larger bar around 05 at the same time that they went to the smaller lift blocks in the back and the different torsion keys in the front to lower the trucks a little in an attempt to get better gas mileage.
My 09 had a larger bar than the 01 that I have now has. The 01 rides better, but the 09 handled highway curves better.
08 was the different T-bar keys and the smaller blocks
I put a larger Explorer bar on my 00. It was from a 97 or 98 Explorer, mounted exactly the same as the Ranger bar and I bought new frame mount bushings for an Explorer. I went with poly bushings.
Thanks, that gives a date range to look for.
Everything listed for the Ranger is too small, including OEM sites. This is the bar that came with the truck. There are enough things different about it compared to the earlier models that it can get frustrating.
Should be the same 97-ish through 01 for Explorer. Apparently there were 3-4 different sizes at least of the bars. But yeah, when I saw the big Explorer bar on my donor that looked like a perfect fit for my Ranger I had to do it, lol.
I had a guy offer me air bags when I went to Kentucky for the 25th anniversary of TRS when I stopped for gas at one point and I’m kicking myself for blowing the guy off now, lol.
2001 was a winner on Rock Auto as a first try. They have several 34 mm options. I guess the Ranger came from the factory as Frankenstein's monster.
