Wheel bearings, wheel bearings, oh wheel bearings.
Hoosierman
Forum Member
Indiana
Now that the weather is finally starting to turn nicer, I'm going to resume work on my '84 BII. I'm going to start by servicing the front brakes and replacing the calipers, as well as replacing the rotors. Looking through the shop manual, it appears the wheel bearings and races should probably be replaced when doing the rotors. I am have a few questions about this job because I feel like I'm not getting the big picture.
While replacing the rotors:
1. Do I replace both the inner and outer wheel bearings?
2. Will the Timken Set45 cover both inners and others for both sides? Is there even a difference between the inners and others?
3. Are the grease seals the same?
4. What else should get replaced that I may be missing?
5. Are there any specific recommendations for what grease to use when packing?
I have yet to jack up the truck and begin investigating, so I'm at the preparation stage. It looks like I'll need a spindle nut tool also.
Thanks
Inners & outers are the same, you need two Set45's per side for a total of 4 races and 4 bearings. Yes I would replace all four at once. Wheel seals are the same on both sides.
If the bearings aren't loose and look to be in good shape then just clean them out really well, repack, and reuse. If you are careful you can reuse the seals too... lol... my cheap ass definitely has done that many times, not gonna spend money on seals if I just replaced them a year ago and am repacking bearings cuz I drove through a creek!
Grease: I just use whatever red high temp I have on hand. I imagine there are many other types that will work too, I just like the red stuff.
Anything else to look at: yes, remove the spindle and at a minimum clean & repack the bearings inside them where the axle shaft rides, replace the little seal there, check u-joints in the axle shafts, and look at the dust seal that should be on the outer axle shaft right where it goes into the spindle - it's probably missing.
Every new rotor I've bought has come with races in it, so buying bearing-and-race sets leaves you with extra races. If you want Timken specifically, though, I do only see the set.
I never use the races that come with new rotors. Timken is about the only bearing brand I trust for quality these days - who knows if the China races that come with rotors are even in spec. National & SKF used to be as good as Timken but they are hit & miss now.
I think it depends on the application. I'm going to be more careful with a trans than with a diff than with a front wheel bearing. Something this accessible--especially in a world where formerly reliable brands are all gravitating towards the same lower level of quality--I'm honestly not that picky.
If we are talking brands, I'm literally dealing with a National kit right now that didn't have the right bearings inside when I opened it. I do like BCA, and don't ever really see people talking about them.
I use the ones that come with rotors as bearing drivers to help install good races lol.
Lots of truth there. I just figure that Timken's on RockAuto are very competitive price wise as any parts store brand, obviously better than anything really cheap on RA, and known to be good quality. They live in a dirty environment too but they're easy to get to. If you're limited to parts store stuff then I don't know if it even matters. I bought some National bearings that said Made in China on the box and the bearings were stamped Made in USA... then there were some that said Made in China on the box and the bearing just had a part number on it.
Transmission bearings are a different story, I've found that you're pretty much limited to whatever comes in the rebuild kit unless you want to spend BIG bucks buying individual bearings. Koyo & Nachi are pretty common in kits and they seem to be good quality. Input shaft pocket bearings are the exception - IMO it's arguably one of the most critical bearings in the kit and they are almost always not even marked with a part number and shrink wrapped to a generic white piece of cardboard. I want the BEST there...and that's very hard to find.
In a differential - carrier or pinion bearings - I am going with Timken and damn the cost. Setting up gears is expensive if you have a shop do it and a bunch of work if I do it, so I have to know that what I'm installing is a quality part.
Like 95% of John Deere bearings companywide are Koyo, they are as good as anything. :icon_thumby:
most spicer will be timken usa. generally. orielly can usually get them i noticed.
they had great price on my d 60 spindles last i bought....
hubs not so much.
just inspect them. if they are good, repack and go.
Lots of good advice! I ordered the parts this morning, and I'm going to pick up Lucas Red n' Tacky along with a 2 ⅜ spindle nut socket at Advance. It seems that Lucas Red has quite a following and from what I gather, red grease is known widely as having molybdenum content. For the uninitiated- Molybdenum has one of the highest melting points (6th highest, I believe) on the periodic table, requiring thousands of degrees to begin melting. That means it handles high heat very well and doesn't break down so readily, making it formidable for applications where friction and inertia are at play.
Red n' Tacky is good. One of my top choices.
I'm trying to use up several tubes of Curtis red grease that I got for free. I don't like it. It's almost more of a liquid than a grease. Says on the tube that it's appropriate for wheel bearings, I guess we'll see.
I need to take the grease tube out of my manual grease gun and see what kind it is so that I never buy it again. Every time I pick it up there's a bunch of liquid grease that drips out. Very annoying, never had that problem before.
Wouldn't that stuff be a little more ideal for, say, ball joints and driveshafts?
Bacon grease tastes better
I dunno, maybe. Seems to be working OK so far. My goal #1 is to use up what I have on hand... once that's accomplished my goal will be to use the same grease on everything unless I have a good reason not to.
Well I managed to get the driver side done today, was quite an interesting day, not too bad of a job- just messy. But I may have another issue, and I have my suspicious by I could use some input.
When I lowered the truck for the evening, the passenger side wheel is crooked, like it's suddenly got a negative camber (I may have the wrong term). I know it's not so apparent in the photo, but it really is irl.
  • Wheel bearings, wheel bearings, oh wheel bearings.
Upcoming TRS Events
Featured Ranger Based Vehicle
