- Aug 13, 2022
Had a misfire in cylinder 6 then changed plugs and wires then moved to 5, it still wouldn’t start, it would turn over but not fire up. Opened the engine up and looked at the intake valves from the fuel injecter sides and it looks like 5 and 3 are stuck open, did compression check before I took it apart and it had good compression in all but cylinder 4 which had 120 rest was up around 180
I feel like I should replace the head, but I want other ideas
