- Sep 22, 2007
- Michigan
- 2.9L
- My credo
- A legend to the old man, a hero to the child...
Thought i had it licked...im starting another thread because the other one derailed...and i got better info now.
Symptoms...
Cuts out around 30-35 under heavy throttle...sometimes will totally lose power....normally wouldnt stall but it did today. Shut it off, it fires right back up, and generally wont do it again untill it sits for a while. Im also getting the red battery light...totally randomly. Sometimes its on for a second...sometimes for a minute...volt gauge never moves and electrical power seems to stay. It is also now...sometimes...missing after you come to a stop. Sometimes after 10min of idleing, sometimes right away, lights also weirdly pulse during this...and its a crap shoot if the battery light lights up during....again...shutting it off and restarting makes it all go away. About 50% of the time it will act like it wants to stall going into gear...it dont...but it bogs out and then kinda chugs back to life. I also for the first time tonight felt what im pretty sure was torque converter shutter.
Codes im getting are for "primary control circuit open/short"...for cylinders 4/5/6/8. One cylinder (4) on pass side bank, 3 on the drivers. For some reason cylinder 7 seems immune...despite its bank mates going crazy.
Also...here are some missfire counters that i have no idea about...
According to the google one of those usually indicates a random/mutiple missfire the computer cannot pinpoint...
So why am i getting specfic codes?
Why does shutting off the key and then right away firing it back up clear everything up?
Why does it only happen early on in drive cycle and under hard acceleration or at idle?
This almost has to be the PCM at this point dont it? Along with the shudder i couldnt recreate and a trans that acts perfectly normal otherwise?
Can some of the heavy hitters chime in here? Im literally pulling my hair out.
Should add...All 8 plugs/coils are new (motorcraft), cam sensor/pigtail are new, intake manifold is new, MAF is new, alternator is new, starter is new, battery is basically new, cats are new, fuel pump is new..ive checked every ground on the thing and they look new (its only been in the salty north a couple years)
Symptoms...
