1988 bronco ii brake installation
Randall008
5+ Year Member
Maine
Hi all, I was working on my car the other day and I noticed the guy that put on the flexible brake line cut the frame where the solid section of the flexible hose inserts into the frame. How concerned should I be, please see attached pictures. Sorry they are not the best.
If I should be concerned, should I just weld it?
Thank you
  • 1988 bronco ii brake installation
I would not worry about it. The strength is in that turned up lip around the edge. I drew a imaginary line (yellow) lined up the with the lip top and bottom. You can see you have plenty of metal in the area that was cut, that matches the height of the lip on the rest of the bracket.
Hi Franklin,
Thank you for your input. That’s helpful.
It bothers me. And I thought about disconnecting the brake line and welding it then putting it back. But then I figured the heat from the welder might warp the metal while it’s under tension from the spring. And I didn’t want to deal with the spring.
Structurally, I figured it was probably fine as is and any repair I did would be more cosmetic and just make me, Which sometimes causes its own problems and it’s just better to leave things alone.
So I appreciate the second opinion. I think I’m gonna take your advice and leave it alone.
Hi Franklin,
Thats the spring bucket anyways. They are replaceable. But honestly it wouldnt worry me ive seen them with much more damage due to rust and not fail
Just so happens I needed to get my BII inspected yesterday, and I have a cool inspection guy. He warned me, next year it's not going to pass because of the front right spring bucket. What? I didn't know it was a thing, but when I got home sure enough, there is a rust hole in it. I checked my parts truck, it has a hole in it also.
I haven't decided whether to get a new one or weld a patch on the old one. I am cheap.
Mines rusted too. Luckly we dont have inspections...id pry be walking.
There is a thread on here where someone documented and took some pictures of taking it off. His frame was ok, but I can see it getting bad enough to compromise the frame and put a hole in it also. I am glad the inspector said something, I am going to eventually do something about it.
I replaced both coil buckets on both my 88 Bronco II and my 95 F-150. The worst part was getting the rivets out and that the replacement buckets don’t always have the holes exactly right so I took to just lining up what holes I could and get some bolts started then run a drill through the holes that didn’t quite line up. Don’t remember if I got the ones for the F-150 from Ford or not, but I know I got the ones for the 88 from ATS Spring.
I know others have documented but it's in my build thread too.
I used a cheap Harbor Freight step bit to make my holes line up. It was awkward putting tension on the bolts before the bucket even touched the frame on one side.
The new bucket doesn't quite hold the spring in place the same way. I have F150 spring retainers. Just haven't put them in yet. 2 offroad trips on the hose clamps and they show no signs of giving.
Yeah, the buckets I put on my 88 seemed ok for holding the springs but the stock buckets on my Choptop don’t like retaining the coil so it has the F-150 retainers which work really well.
I was doing a search about it, I think it was your thread that came up. Should pull that part out and put it in the tech library under suspension.
Not sure how I'd make that long enough to justify an article. Literally everything short of step by step is in my previous post.
I could do a step by step if there is interest.
