need a little more power
Was you in tow/haul?
My 5.0 bumbles around in normal, in tow/haul it gets is crap together and acts like it knows what it is doing. It is a totally different truck.
The 2.7/3.5 are supposed to be really good for towing, I have never tried one.
Tow haul really makes a dramatic difference in these trucks. My SD feels real ho hum just cruising around but in tow haul it feels like a monster.
My buddy has a 16 F150 with a 3.31 and a 5.0 its pretty impressive towing. Still gets like 10 doing it though
IIRC the F150 EcoBoost trucks had a higher tow rating than the 5.0 but the 5.0 trucks had a much higher payload capacity or something like that. Kind of weird.
My V10 super duty is also real snappy in tow/haul but not in normal mode. Seems like it is getting worse, it may need plugs or may have plugged cats. In any case I think 95% of the difference in tow/haul is in modified auto transmission shift patterns. 5R110's are the pinnacle of perfection in automatics... I have never driven anything else that has the shift pattern timed so perfectly.
i believe so. i know to use tow haul so i want to say yes but its been a while so i cannot say 100% yes, other then i use it on any other vehicle when towing that has the option to turn it on.
Yeah tow haul changes shift points and converter lockup....and on drive by wire rigs i believe it also messes with allowed throttle opening....but not for sure.
Im guessing the EB is heavier then the 5.0 so that eats into available payload. Which, if loading legally may make towing numbers alot closer in real life then on paper.
I know the diesel guys get irritated the 6.2 trucks carry a higher payload then the PSD due to engine weight.
