V8 swapping 83 ford ranger
(update) i got a 1986 Lincoln mark 7 with a 5.0l ho efi with a aod transmission i just need some guidance on transmission mount and if the motor and transmission length are the same as a 2.3l 4 cylinder inline and a c3 transmission of what i would need to do to det a correct length driveshaft for it
As bobbywalter said, you'll have to measure the driveshaft.
I have 2k miles on a 302 & T5 swap in a 1990 Ranger that I finished in December. The driveshaft was my biggest concern until I actually measured it and found that the shaft I had from a 4-cylinder, manual Ranger was only 1/2" short. I'm running with that since there is plenty of yoke still in the transmission.
IF yours is a 2wd Ranger, take the yokes off the driveshaft (you'll probably want to replace the U-joints anyway). Slip the front yoke into the AOD all the way and pull it out 1". Then mount the rear yoke to the axle and measure from center to center of the U-joints. If your driveshaft needs to be shortened, any driveshaft shop will be able to do so cheaper than having a new shaft made. Do a Google search for driveshaft shops in your area. I bet you'll find someone. Make sure you ask them what measurement they need for modification or a new shaft. Some shops want a measurement from different points like U-joint center to center or the end of the output shaft to pinion flange.
As for the transmission mount, the crossmember will most likely need to be relocated and the transmission mount bolt holes drilled out. I bought my Ranger without a transmission and the crossmember and mounts had been removed. RicksRangerz has a raised transmission crossmember that will bolt in anywhere you want on the frame and accepts T5, C4 and AOD mounts. You'll have to drill the frame to bolt up the crossmember, of course.
I just noticed you are in Colorado but don't mention city. I highly recommend Colorado Driveshaft. When I trans swapped my 1948, they were honest and said they could rebuild a junkyard shaft (shorten) for 1/5th the price of build from scratch. So I spent a couple bucks at lkq u-pull-it and got a driveshaft from the junkyard, an extra knuckle (because it was a trans swap from a two totally different styles trans) handed it all to them and it was dirt cheap to have them shorten and balance and make a shaft I am quite happy with. Might sound like a sales pitch but I promise I don't represent them or work there or or - I just have a 1948 that I swapped from a 4 speed rock crusher to a 5 speed OD synchro gear modern trans.
Good JY shafts are hard to find, when they move vehicles with payloaders they usually get crunched.
I had to search and search before I round a truck that had been junked over the transmission... the transmission was all tore apart in the back of the truck along with the driveshaft.
car-part for shelf driveshafts.
often i let the stock driveshaft in this scenario dictate powertrain location.
this makes sourcing easier as it is a known. but can cause other custom situations upstream.
thank you very much for the information i really appreciate it it helps alot add on your ranger does it have the 9 inch rear end and what is the gear ratio ??
I'm just running a 7.5" with a factory limited slip and 3.73's from another Ranger. I don't really plan on launching hard in my truck and it doesn't have any kind of traction aids. My thinking is the 7.5 should hold up if the tires can break loose. Wheel hop may be a different story. I'm no expert here. If the 7.5 does break, there are plenty of 8.8's in junkyards.
If you're going to run big tires for off roading or planning on drag racing the truck, then you'll definitely want an 8.8 or 9 inch rear.
I'm not going to use it for off roading or drag racing its going to be a daily driver. I just want to be able to get on it and not half to worry about destroying the factory rear end. Everything except the motor, brake booster, brake master cylinder and radiator is original from when the truck was built 43 years ago. As well as common replaced things like plugs, wires, cap, rotor and distributer.
I would recommend 3.45 as a good ratio for a daily driver. Mine had good acceleration and would run 70mph around 2000 rpm with the T5. I'm honestly thinking about going back to that ratio or maybe a 3.55. 3.73 seems too short for the tire I'm running (245/45R17).
