1989 Interior Leak ID and Fix
jprevat
10+ Year Member
Georgetown SC
I have an 89 bronco 2 that has a pretty severe interior leak under the dash on the passenger side. I had the windshield replaced just to eliminate that being the source. It fixed most of the flow but this specific leak remains.
Can anyone tell me what I'm looking at here and how to go about sealing it? I really want to save my factory carpet before it's too far gone.
Thank yall ahead of time.
Thank you for the links. Ill have to see if I have the access panels under the hood and then pull the dash as a last ditch effort.
I just did a little water testing and it seems like the passenger side cowl drains much slower through the fender than the driver side. Is there any way to clear the drain by pulling the quarter panel?
Going by memory from over a decade ago, I do recall taking the fender off mine for a repair and there was a small slot opening in each side of the cowl area for water to drain out. Perhaps that slot is clogged with leaves/twigs/other debris.
I kind a remember there being a piece of leather like stuff closing off the hole. Acted like a one way valve.
Ill have to pull it and see what I can find out. The passenger side still has dripping water out of the fender 10 minutes after the driver side has gone dry. So I am really hoping I can undo whatever is stopping it up. Maybe if the water doesnt back up I wont see intrusion in the cab anymore.
Unblocking will not fix the rust hole you have. But maybe it gets the water level below the hole...
I too seem to remember seeing something mangled-looking in there that wasn't leaves or twigs, but wasn't sure what it was... I just cleaned everything out of there so nothing was blocking it.
Reviving an old thread instead of starting a new one. I ended up storing the truck out of the rain so a fix wasnt urgent but I decided to get back into it after two kids and many delays later.
I pulled the access panel on the driver side and found deep leaf litter that had basically become hardened mud. I broke it up and vacuumed it out and that channel actually looks great. I took the time to pull the passenger fender to get at that drain and it had some trash but nothing like the driver side.
The guy above me was right there is a rust hole or the seam is exposed in the channel. Do I just cut the spot welds and peel the cowl up or do is there another way? Can I get to the seam if I pull the AC heater box and blower or is that even more work?
Thanks in advance guys. Pics just because.
Unfortunately cowl access in these kinda sucks. The F-series trucks had a cowl that bolted in, but on the Ranger/Bronco II/Explorer they are welded and the panel goes into the windshield area.
On my one truck that was having a problem, I had the fenders off to get access to the core support for replacement and I used a large hole saw on the drains to the point that I could squeeze a hand and arm in there. Then I used roof grade urethane to seal up the seams. Probably not the best solution, but back when I did it, that was the best solution I could come up with and do. Seems like it worked though.
@holyford86 just recently made an access panel on the passenger side of the cowl on his one truck
That sounds like a great idea to me. Ill cut out the ends and see if I gain enough clearance to make it work. Hopefully holyford will share too. You can never go wrong with more access.
Unfortunately the cowl seam goes up under the windshield and is spot welded together there (the windshield actually glues to the same piece of metal the cowl is made from) I am refurbishing a cab that sat for 30 years and had a mouse nest in the cowl, which rotted it out. I cut a hole on the passenger side top and made an access panel because I needed to get a welder in there, which I couldn't do because the hvac intake is in the way. I made a nice stainless steel cover for it as well. Once I get my paint done I'm going to put some butyl seal around the outside edge and leave it raw stainless after. I was leery of cutting the ends out because I didn't want to affect the structure of the cab.
That will look great when you are done. I think that may need to be the direction I take as well. The way the water is coming in I dont think there is any way I wont have to weld some in the valley.
