2.5L ('98-'01) 2.5 8 plug coils/plugs wiring
peepaw truck
coconut head, according to my friends
ASE Certified Tech
Landrum
SC - USA
Vehicle
Drive
2.5 (4 Cylinder)
No
No
225/70R15
Retired tech. Started with Ford but most of my career with Honda
Hi ya'll. I'm in need of help with my 2000 2.5 8 plug. I hired a guy to do plugs and wires and now the idiot cant remember how to wire the coils. I thought I saw a diagram on this some time ago but can't find it. Can anyone help? Thanks! Edit- Below is one I found. Can anyone confirm this is correct?
  • 2.5 8 plug coils/plugs wiring
I posted a picture HERE if you scroll down a bit, it shows the coil with numbers on the Motorcraft sticker, on both coil packs just make sure 1 and 4 are on the 1 and 4 side and 2 and 3 are on the 2 and 3 side, you can mix up 1 and 4 or 2 and 3 but not across those pairs
Thanks. I found a diagram shortly after I posted and got the job done. Local shop wanted $300 to do plugs and wires. My neighbor wanted to help me because I've fixed a few things for him and I'm dealing with a neck injury. Good guy but hopeless at car repair. Lil Red is running great at 280k plus.
Well, misfire came back. Out of curiosity I hooked up my old timing light on the right side plug wires and found some were misfiring. The coil pack had a bit of oil/dirt residue. I replaced it and the truck runs much better. But now I've got spark knock under heavy throttle. Anyone else encountered this?
My old 2000 2.5l would always ping under high load. I replaced the timing belt after it broke and 80% of the pinging went away.
Thanks for the reply. That's really weird though. Usually the opposite is the result of slightly retarded cam timing which what a worn belt would typically do. I have found that my Ranger loves to do the opposite of what normally would happen in most vehicles.
Ok , my latest adventure is the truck killed the battery i had just checked a day ago as as fine, cleaned all connections, alternator/voltage regulator all checked good. I have heard a relay clicking under the dash at times ever since I've had it. I charged the battery, cranked her and confirmed everything checked out. The only draw worth mentioning was the interior light fuse. Seems like I've seen threads that addressed stuck relays & that's the only reasonable explanation I can come up with. If anyone has insight on a likely culprit for this, please reply. Thanks!
Honestly it could have been a placebo effect. I just remember less pinging every morning on the up hill on ramp going to work. Maybe I was revving it higher between shifts
