Is the 2002 ford ranger fx4 off road a stronger and tougher truck than the 2002 chevy s-10 z-r2
Gary DuBois
5+ Year Member
💻 TRS Socials
Puyallup Washington
N/A
Vehicle
Drive
31 inch
Would a 02 ranger win in a tug of war against a 02 s-10.
What are your opinions on those 2 trucks in all there aspects.
chevy is my 3rd favorite.
they are both good trucks, both have their strong points and drawbacks
In your opinion how are they both good trucks and what are their strong points and drawbacks.
I like the s10 my grandfather owned one from the late 80s
A lot of times it comes down to traction and the angle of the road. A truck pulling uphill will have to fight gravity and the power of the other truck vs. a truck pulling downhill, which will have the advantage of a downhill pull.
You also have reaction times. When it's time to pull, who is faster to take off? This can be the difference between winning or losing.
Then there's the transmission. If one is an auto and the other is a manual, the manual may have a disadvantage to the auto if the clutch is worn.
A million potential variables here. Gearing, engine, transmission, tires, if a truck has a limited slip or locker, weight, etc.
That said, and after having a little experience with the S-10, stock for stock, that the Ranger would probably win a tug of war. My 2wd Ranger went better than mom’s friend’s 4x4 S-10.
Tug of war is a worthless metric.
This too. Like burnouts, which only means your vehicle is capable of producing more power than it is capable of transferring to the ground. I’ve gotten into a couple disagreements about that with the 5.0 AWD swaps I’ve done on Rangers. Someone says to do a burnout and I say it won’t do it because it’s AWD and they say well your vehicle isn’t anything special if it won’t do a burnout. Well, lemme tell ya something Jack, you sit here and do a burnout and I’ll be waaaay down there because I have the traction to just take off instead of “looking cool”
not only this, but doing a burnout in an AWD is reaaallllly hard on the transfer case and tires are not cheap...
AJ
Its still fun though.
Except the time my 300 got scooted backwards by a 4.3L 1\2ton.
Probably helped he was spinning 55mph and i was in creeper digging woodchuck holes.
My old 78 dually with a 400 managed to drag a 6.9L around....that was fun.
But yeah....tugs only prove weight and traction really.
