Temp gauge
1994xlt
Forum Member
Morton
IL - USA
Vehicle
Drive
Stock
Stock
good question
Hello yall as you may know I had a motor put in my truck a few weeks Ago and this week I noticed my temp gauge won’t work right, the heat blows hot and stuff but the gauge never gets to the normal Range? The thermostate is new so it shouldn’t be that but I guess it could, but went I’m like on it an accelerating the needle goes down significantly then it might creep up after a bit again but then go back down again after driving at a steady mph for a bit. I went to o Riley’s but think I got the wrong part I got a temp sender but I think I needed a temp sensor?
Temp gauge
That should be the right one. The older trucks had two. The single terminal one is for the dash gauge, the one with two terminals is for the ECM.
Well now I’m curious what goes bad in these? There literally a stud
They can really only go open or short. They just provide resistance to ground. The resistance changes with temperature to make the gauge move. You can force the gauge to one direction by grounding the wire. I think there is actually a chart floating round the 'net of resistance relative to temperature somewhere.
IMO, it sounds like you have air in your cooling system or voltage to the gauge is varying significantly. The gauge will vary with voltage. If you're sure you have all the air out I'd probably rig a voltmeter up to the lighter socket and see if the voltage matches the gauge dips. It'll probably be inverted. As voltage goes up the gauge goes down.
im guessing something is connected poorly
Well I ended up getting the part so I guess I’m gonna dig into it today I gotta change my oil and stuff anyway
To ground the wire do I just stick metal in it or what
  • Temp gauge
well i can see why they would say that it would kind of insulate it from the block but whenever you screw it down its going to make a good connection
Sorry, I’m kinda of confused what your saying
teflon causing a bad ground is why i think they say not to use it
but i think it would just, for lack of a better word, "bite through the teflon"
Ah ok
Usually that's the case. To test the gauge yeah just poke a wire into that end and touch it to the engine. Gauge should peg. But we already know your gauge does something. It's possible you have a bad connection somewhere. IIRC that wire was pretty hard to install on the sender. If yours' isn't, it may not be making a good connection causing the gauge to move slightly. Maybe have a friend wiggle the connector while you watch the gauge. Engine not running, just key on. Or setup your phone to record the gauge while you wiggle. Might catch something.
