Roof Racks for second Gen rangers
RangerRyan1990
Austin
TX - USA
Other
1997 Custom Built 85" Evo Big bore Softail style Chopper
Vehicle
Drive
None
None
235/75R15
I'm interested in putting a set of roof rack bars on my 1997 XLT extended cab. And then Once the roof racks bars are on I'd like to install a metal off road style rack on top of the roof rack bars themselves to keep a spare tire and a hi-lift jack on so that it isn't taking up space in my bed. Has anybody had any experience with installing roof racks on a second gen, and if so what size/measurement of roof rack do I need to get and what websites did you get your setup from? For this part of the truck I'm not looking to spend an arm and a leg, just want to do it as cheaply as possible. Also, I'm not opposed to drilling holes in the roof to mount an off road style roof rack onto the truck either if that's what I need to do. Any advice or wisdom is greatly appreciated. Bonus points if anyone has pictures of there second gen rig after installation of a roof rack. Thanks y'all.
Second gen has a much different roof than yours. The roofs are the same from your third gen up to the fifth gen (2011) if that helps any.
1997 is a second Gen. It's the last year of the second Gen rangers. First gen is from 83 to 92, with the facelift for first gen being done in 89. Second gen is from 93 to 97 with the facelift being given for 2nd gen in 95. 3rd gens are from 98 to 2011, with multiple facelifts being done for that generation. Each generation of ranger model has had at least one facelift during the duration of that generations production. However, I'm not here to argue over this or that. I'm reaching out and asking for advice from anyone who's actually done what I'm talking about doing. Isn't that the point of a forum? I've been messing with rangers my whole adult life and buying and flipping them, but I've never done a roof rack install like I'm wanting to do so trying to see who has done them so I can get some input. I have tons of parts, literally an entire 40x45 garage sitting beside my main shop that is packed with ranger parts of all kinds from front to back, But I don't have a roof rack on my garage and I've never thrown a roof rack on one and simply wanted some input from anyone who has. That's all.
Now, back to my question on the oist. Do you know what kind of roof rack setups I can use for the cab roof on my second gen? IDC if I have to drill holes in the roof, that doesn't bother me one bit, I just want to find an affordable solution that works for me. Any advice or experiences you've had with this is welcome.
  • Roof Racks for second Gen rangers
Ford doesn't care about "generations" they changed things around in between what anyone calls generations.
The post I linked is put together by input from Ranger enthusiasts who live by working on these trucks, actually the owner of this website (@Jim Oaks) is the one that made it.
89 "Facelift" was major. Front clip obviously is different. Inner cab structure is changed to support the new dash making a dash swap rather difficult. Rear wheel arches are bigger. Wiring is totally different. fuel systems are different, Powertrains were changed. Very little directly interchanges between them.
Really a 89 has more in common with a 93 than it does an '88. Electrical systems are more similar, powertrains are have more in common and the dash (93-94) is the same while all the sheetmetal is still different.
I don't care what you want to call it, as someone who hunts down' parts for a first gen (83-88) a second gen (89-92) is nearly worthless to me for a direct replacement part. Pretty much everything is different. When everything is different... to me it is more than a facelift.
1997 is a second Gen. It's the last year of the second Gen rangers. First gen is from 83 to 92, with the facelift for first gen being done in 89. Second gen is from 93 to 97 with the facelift being given for 2nd gen in 95. 3rd gens are from 98 to 2011, with multiple facelifts being done for that generation In 01, 04, 06 & 08. Each generation of ranger model has had at least one facelift during the duration of that generations production. You seem to be confusing certain year facelifts with actual generations, the 89 model changes were a facelift, not a new generation. First gen had its facelift in 89, second gen got its facelift in 95, and third Gen had multiple facelifts. First gen is 83-92, second gen is 93-97, third Gen is 98-2011. You can Google all of this for further clarification, and you can also check What Ford Motor Co says about this as well. I get that your basing your assumption off of someone's post and what they think the generations are or should be, but Ford is very clear about what years constitute what generation, and wether they are Pre, or post facelift models. Going off of what the post you're sharing is saying, 83 to 88 is its own generation and the facelift in 89 means that 89 to 92 is a seperate generation. But then in that same post it says a "3rd gen" is from 93-97. However, that year range (generation) also had a facelift in 95 (which is what happened in 89 that you're saying is what makes 89-92 a different generation) yet you don't split 93-95 and 96-97 into two seperate generations? That makes no sense whatsoever. So some facelifts constitute a whole new generation and some don't? No. Not how it works. And going off of that posts assumption then that one facelift year creates a new generation, that would mean then that all facelift years create a new generation, meaning that 83-88 is gen one. 89-92 is gen 2. 93-94 is gen 3. 95-97 is gen 4. 98 to 01 is gen 5. 02 to 04 is gen 6. 05 to 06 is gen 7, and 07 to 11 is gen 8. Do you see how this doesn't make sense? You can't just say one facelift, that Ford motor co even says is just a facelift for that generation, is a new generation, and then say that another facelift in different years doesn't make a new generation. The facelift years do not constitute a new generation, a facelift has been given at least once to each generation. Ford is very clear about that. I get that the post someone put up says what it says, and everyone is allowed to define or identify anything however they want to in this day and age, but that's not how Ford Motor Co. defines them. Again, you can Google all of this yourself if you don't believe me. Hope this has helped you to understand this better.
Now, back to my question. Do you know what kind of roof rack setups I can use for the cab roof on my second gen? IDC if I have to drill holes in the roof, that doesn't bother me one bit, I just want to find an affordable solution that works for me. Any advice or experiences you've had with this is welcome.
Cheeky fellow coming in here acting like you know everything. I’d be careful if I was you.
I’ll move this to where it goes in the forum for now.
89-92 was not a “facelift”. In addition to the front clip, dash, and electrical changes, the front of the frame changed. I don’t care what anyone finds on the internet, when the frame changes, it’s not a “facelift”. Period. There’s a better case to be made about a “facelift” for the 98-00, 01-04, 05-08, and 09-11. Frame changes were 83-88, 89-92, 93-97, and 98-11. Cabs were essentially the same 95-11.
I do not know of any roof racks that you can buy specifically for the Ranger, but they may be out there. There’s likely a lot of universal ones and stuff that can be modified. I’ve thought about it, but anything you put up there adds weight to the wrong part of an off-road rig, the tallest point. I am contemplating making something up there on my Choptop when I do a hybrid cage to it just because I’ll be adding structural steel up there anyway and it might not be a terrible idea to stick a couple Packout bases up there just in case I ever need it.
What they said on the generations.
As for the rack, I never seen anything made for the Rangers, any year. Maybe the latest, but I haven't looked for those. What I have seen is someone cut down an Explorer roof rack to fit. The for yours the 95-01 roof shape is similar enough that it can work. Haven't done it myself, and I can't provide pictures, just seen it done in the past.
I am planning to pull the rack from my donor Explorer to install in a camper shell if I ever decide to get one, but that's a different project. Not sure how sturdy the rack would be on either install, and for the shell I'd probably be building a support structure inside the shell.
I have checked out a few universal ones, I'm somewhat Leary on buying the ones that have to mount with a strap running under from door to door, but I have seen a few that look like they "may" work. I'm almost thinking that buying an actual off road roof rack and bolting it right through the metal roof of the cab may be the best bet. I got the truck home three days ago and I have completely removed the headliner and the seats, and I'm in the process of pulling out the carpet as we speak so while that's all out I would be able to drill and bolt what I need to. With this truck, unlike my 2011, I am just trying to do a budget build on it. Not trying to dump a bunch of money into it. This will just be a cheap little daily driver. I picked it up for $1000 cash, it's got a straight body, runs great, shifts great, and absolutely NO rust anywhere. Only has 87K miles on it. The lady I bought it from's husband passed away and he kept it in a climate controlled garage here in Texas and seldomly drove it. I got a great deal. Just not trying to dump too much money into it like I did with my 2011, I've gone belly up on that thing. I'll never get what I got in it back out of it.
I get what you're saying about the weight distribution too. I plan to just throw a spare tire up on it and a hi lift jack. I don't "think" that'll be too much weight but man you never know really. I definitely like the looks of the ones I've seen with the roof racks but some of those have had some serious money invested in them so idk how doing it cheaply will turn out. I have a ton of aftermarket parts for these things in a garage here beside my shop. I've got a whole seperate 20x20 area inside this garage thats packed full of nothing but wheels, and aftermarket lifts and suspension components for them. I've decided I'm going to throw on a mild 2.5" lift kit I've got sitting around. I recently found a snorkel kit I got for a 1996 XLT I used to have but this one I just got is just a 2wd so I probably won't use the snorkel at all, just the lift kit. I've been a Ford Certified Master Technician for over a decade now and buying fixing and flipping rangers has always been my projects to keep me busy and to make extra money as a side hustle. I've amassed an ungodly amount of aftermarket and upgrade parts for them I'm sitting on. My son's got two rangers as well he's built. Most things I am comfortable with but since I've never done a roof rack on an off-road rig I figured I'd ask for some input. I'm thinking I'm just gonna bolt one right to the roof metal though. Prolly the simplest solution.
I will look into that. We have a 1996 explorer here, that may work. Thank you for that input. I appreciate you
Funny how the Ford Ranger community was united in the breakdown of Ford Ranger generations in 2011 and then the Ranger was reintroduced in 2019 and suddenly people want to jump on the Ford Ranger bandwagon and redefine them.
So based on that nonsense, my 1996 is a 2nd Gen and my 2021 is a 4th Gen. Good grief. Whoever came up with that obviously wasn't part of the Ford Ranger community very long if ever.
We've been doing this for 27-years. There isn't another Ranger site out there older than TRS. Sites have come and gone and now we have to contend with a whole new generation of Ford Ranger owners that want to rewrite history.
FYI - I wouldn't put a spare tire and a Hilift on the roof of your Ranger. That's a lot of weight that you're sticking above your center of gravity, and it will adversely affect it's handling and increase its chances of rolling over of you get it off camber.
Like a bedrack that overhangs the cab would be great.
There isn't much structure to a ranger roof.
:agree: Apparently they aren't content with doing it to world and national history, they've got to mess with the Ranger as well. I wish it was limited to the period since the reintroduction, wikipedia editors started it long before that. I remember trying to correct it myself years ago, but wiki has always been more of a popularity contest than fact based. They'll reference other material and work, but only what supports their narrative. It's amazing how much those editors use circular logic. Wikipedia must right because that's what Google says, and Google must be right because that's what Wikipedia says.
Going by what they are trying to say with the Rangers there would only three generations. First gen being 83-97, Second being 98-11, and third being 19+ trucks. With that take on things, first gen got a face lift (front clip) and a new smile (interior) in 89, and a face lift with body sculpting (new sheetmetal) in 93, and a new smile again in 95. They are generalizing the components so much that the trucks may as well be the same thing below the sheet metal. In reality there were big changes in that range that those people ignore as noted by others above.
I thought that all 1983 to 2011 Rangers used the same sheet metal stamping for the bed floor, in either short or long box.
So, arguably that would make for just one generation, right? :icon_twisted:
I'm just going to put Datsun badges on my truck and call it a Datsun. :icon_twisted:
By Wiki and Goggle logic, yes.
I say if you’re going to ignore historical points, then the generations should be decided by frame changes. The frame makes a more logical point to determine generation because it’s the base the vehicle is built from. A “facelift” or “smile” is cosmetics by definition.
I have considered something like that myself. Even thought about combining the "roll bar" a rear hoop (maybe in the stake pockets) and a forward hoop attached to a custom front bumper for carrying long ladders.
