94 explorer mania swap
RubyRanger16
ASE Certified Tech
Port Coquitlam
BC - CAN
Vehicle
Drive
8”
I just a did a manual swap on my 94 explorer and having some idle issues no I don’t have the manual ecu in it, it’ll idle at 1500rpm but then when I push the clutch in it’ll drop down to the correct idle 700rpm and stay there but the second i release it idle jumps right back up, unplugging the iac keeps the idle perfect, does this sound like I need the 94 manual ecu or is it something else?
So, the auto computer is known to cause idle issues.
That said it also sounds like you have another issue. Vacuum leak, bad IAC, problem with the TPS, you’re gonna need to run some checks
Good idle with the IAC unplugged says something is wrong to me. It should idle very low without IAC.
That said if it can be consistent while the clutch is pressed, maybe find the computer signal wire from the clutch and put it on a hidden toggle for adjustable idle? LOL
I figured it be high my friends 94 with manual swap idle at 700-800 definitely not a vacuum leak if it idles fine with clutch in, I had a spare iac i replaced it still same issue
I have a spare iac I swapped it in still same issue, the truck would probably die if it was unplugged at the correct lower rpm, I also think it maybe computer since the check engine light also comes and goes
A vacuum leak could definitely still idle fine with the IAC unplugged. Unplugging it should make it idle super low or kill it. The best way to find a vacuum leak is with a smoke machine. 4.0s are notorious for a vacuum leak around the lower intake manifold.
My Choptop with a 90-92 Ranger 4.0 and the auto trans computer from then with a manual transmission idled around 1,000-1,200 RPM. That’s because that’s where it’s set for an automatic according to the computer.
Manuals should idle 7-900 rpm.
Parts quality anymore is garbage so just swapping an IAC doesn’t necessarily rule it out.
Throttle position also helps control idle. A bad TPS can cause idle issues. You can check its function with a multimeter, tons of threads on here that discuss how to do that.
Yes it could, but when I push the clutch in the idle comes down to 800rpm so that seems like it rules out vacuum leak I’ll check again tonight I sprayed the vacuum line area on side of manifold to make sure nothing there, seems like it’s electrical, also the motor is fresh every gasket is new, I have another throttle body I’ll swap the sensor and see
You need a manual ecu to even start from. The automatics IAC tables are entirely different and the load variation is different from having a toque converter as opposed to a flywheel that duly disengages the load from the engine when stopped.
My volt meter was having a heart attack so couldn’t get a solid reading on it but if you unplug it well it’s running should it change rpm or anything?
what harness are you using? specifically on the trans side...
what nds strategy are you incorporating? ngs switch present?
did you incorporate the triple function switch correctly? unplug the triple function switch if you did.
or is it still on the auto triple function switch jumper?
I’m using the auto harness I’ve snipped the plug off have the reverse lights hooked up and this manual I got had the second sensor for nuetral so that’s all hooked up to the nuetral safety wires everything is duetsch connected, clutch switch is plugged in via just unplugged the jumper and plugging it in
depending on actual hardware and setup pin 30 getting power can harm a manual trans pcm...so if you only have auto then it seeing ground is a thing depending on actuals.
i have see where the wiring was wacked via the accs too...and ended up raising the idle with clutch in or out...dont remember.
same deal, just wires cut and re routed.
its possible you are signaling it so pop the triple funtion plug off and figure that out...with the wire off if the idle situation stays the same clutch in or out then look at exactly what you have.
Sorry little lost what triple function switch are you talking about? The clutch switch? What wire should I be checking for?
auto looks to see crank power to know it is in park or neutral generally...
if you pulled the triple function jumper out from the harness and hooked it to the clutch switch and you are sending the wrong signal to the 30 that may be where the idle surge is.....start it up and disconnect the clutch switch....if the idle quits changing widely with the clutch in, then see what you are sending
neutral in auto switch sends power to 30 on crank....in manual...it hooks 30 to 46
I did this the other day I had the truck off I unplugged it and re connected the jumper then fired up still idled high and pressing clutch in didn’t change it but I’ll check it for power tomorrow then, I bled the clutch tonight so I could put it in gear if I had the clutch in it and in nuetral it would Idle fine put the shifter into first still holding clutch down the idle would jump up then the second you go back to nuetral it goes back down, i ordered the manual ecu off rock auto it’ll be here Monday if all else fails
