- Apr 3, 2021
- Phoenix, AZ
Ahhh............Understood
And perpendicular too.
The tool I bought from Napa over 40 years ago looks like this and works fine. I agree that it's important to get a clean cut on the line and file off any burrs before flaring. Practice a few times and go for it. Remember to put the fitting on the line- facing the right way- before you start.
Extra points if you get two nuts installed or one backwards... not that I would know anything about that... I've installed swagelok fittings a few times and had two nuts on the tubing many times though...But leaving the nuts off is how you get a perfect flare every time!![]()
and not on the line backwardsFIFY![]()
When I bought the kit I was a mechanic in NH, with all the road salt I made a lot of brake lines. All the nipples are still original.this is good if you dont have to make brake lines very often and are on the bench.
only thing i used for 30 years....have a handful of them laying around..
the 3/16 nipple usually busts off after about 20 or 30 uses....which could be a week for me some years...but i was always able to get the dies and had a herd of them up until the mid 2000s.
but ..
making a flare in a wheel well or the frame rail behind the tank is not a thing it can do...
what i listed above...is a god send in regards to that.
i had several turret hydro units...they are worth their weight just in time saved.. but hard to replace because they disappear quickly in the field.
